Question about Kyocera FS-1118MFP Laser Printer
How do i resolve error code c6020 - Kyocera FS-1118MFP Laser Printer
  • Kyocera Expert
  • 337 Answers
Replace the fuser
Posted on Jan 02, 2014
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Code c6020 180
That is a fuser error. Replace the fuser & reset the code in service mode. You will also want to update the firmware of the machine.
Dec 13, 2013 | Kyocera KM-1505 Copier
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
Mar 10, 2012 | Kyocera Copystar CS-1820 Black and White...
How to fix code C6020 of kyocera km1820
how to fix error c6020...1st step is go get a gasoline and a match and then pour the gasoline to the kyocera and then lit it with your match stick...it will automatically restart..for more details contact your kyocera supplier.
Nov 04, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Jun 21, 2010 | Kyocera FS-1118 Printer
How to solve error c6020 for Kyocera KM-2035 copier? it has stopped
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
May 18, 2010 | Kyocera KM-1505 Copier
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Error code C6020
Sounds like you have a faulty thermistor. (heat sensing device) The 6020 indicates an abnormally HIGH temperature. If the readings are greatly different in the two thermistiors or one is not touching the hot roller could also be the problem.
Jul 30, 2009 | Copystar Office Equipment & Supplies
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera FS-1118MFP Laser Printer Logo
159 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
