Question about Denon AVR-689 7.1 Channel Home Theater AV Receiver AVR689
Denon receiver problems
I have a Denon AVR689 Receiver. A few days ago, the sound is no longer heard from the speakers. The Denon system powers up fine. The remote control and main unit correctly switches between my Blue ray player on Quick Select 2 button, and selects my TiVo box for Quick Select 1 button. And when I press the remote control increase and decrease volume buttons or use the volume dial on the main system, the dB values correctly increase and decrease. What can I try to determine the problem?
  • mwmw90 Apr 27, 2013
    I tested Quick Select 1 and Quick Select 2. The suggestion to connect headphone revealed that sound was workking fine. Once I removed the headphones from the jack, sound was coming thru the speakers again. Thank you for the help!
    Genius:
  • Denon Master
  • 1,054 Answers
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Posted on Apr 26, 2013
Mwmw990's solution for the no sound problem was correct for my Denon AVR-488. Other solutions in various forums did not work for me. My amp just suddenly quit outputting sound from the speakers. (I only use the main "zone.") I did not get a flashing standby light, no indication of overheating or overloading. No input would output sound via the amp to the speakers. I switched the zone switches back and forth and it kept saying "H/D ONLY." I plugged in my headphones and heard clear sound. Plugging and unplugging the HD jack in and out and "roughing it up" a bit must have freed up a sticky HD connector because suddenly the display said "SPEAKER" and I have sound from speakers again. If it keeps needing this fix I guess I will need to take in the unit to replace the headphone jack input connector. Try this simple fix first!
Posted on Jul 27, 2013
  • 2 more comments
  • Bill Olinger Jul 27, 2013
    My AVR-488 had the sudden "no sound from any speakers" problem but there was no flashing standby light or shutdown indicating overloading/shorting/overheating. It was a sticky headphone jack, like the first answer suggested. Plug a HD jack in and out repeatedly and wiggle it around. Apparently they stick and the unit thinks there is a HD plugged in, which automatically shuts off speaker sound!
    Sorry, I meant above to say H/P for HeadPhone, not H/D.
    And I meant to say that Steve K.
    That Steve K.'s solution was correct, not mwme990, the one with the problem.
5 Suggested Answers
  • 93 Answers
SOURCE: Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Posted on Nov 06, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
  • 101 Answers
SOURCE: Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Posted on Apr 20, 2010
Power keeps cutting off. stays on for 3 seconds
Could be either a problem with the amp or a bad voltage regulator. Hard to tell without checking some things inside.
Jul 30, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
I have a Denon avr689 and no sound comes out of it??? It worked fine and now it doesn't? My wife hit some buttons on the receiver and hasn't worked again.
Using FM as the test source and turning the volume to something medium, I'd look carefully at the front panel for some indication that Ext In, Muting or a Tape is selected by mistake.
Next, crack the manual and treat it like a new installation. See if the test tones work and go from there.
Feb 02, 2011 | Denon AVR-689 Receiver
Connecting computer speaker to a receiver
Which output section of the Denon are you using? Tape monitor out? And are you getting sound through the speakers (not the PC speakers) that are attached to the Denon speaker terminals?
Oct 26, 2009 | Denon AVR-1601 Receiver
Was it a good buy
Have you ever heard of Quad, I bought my 33/303 set up 30 yrs ago! still sounds great. If you can find Tannoy speakers (Reds or Golds) for sale, a good pair will cost more than they did nearly 40yrs ago. Good equipment should last a long time.
If you like it keep it and enjoy the sound, set it up the way you like it and have fun.
Hope this helps, thanks for using Fixya
Sep 24, 2009 | Denon AVR-1604 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Denon AVR-1905 Receiver
Hi again,
Any new developments?
May 25, 2008 | Denon AVR-1905 Receiver
Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Dec 22, 2007 | Denon AVR-3806 Receiver
Avr-2802 constantly restarting itself and flickering on and off
check all speaker wires from the receiver end and the speaker ends. Just the smallest strand of copper could be touching something it should not be touching. Make sure all copper is in the speaker post and not hanging out. The receiver is getting a short and shutting off to protect it self. This could have happened since you were just plugging things in.
Jul 29, 2007 | Denon AVR-2802
Denon AVR-689 7.1 Channel Home Theater AV Receiver AVR689 Logo
626 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
