Question about Denon AVR-689 7.1 Channel Home Theater AV Receiver AVR689
Denon Problems I have a Denon AVR689 Receiver. A few days ago, the sound is no longer heard from the speakers. The Denon system powers up fine. The remote control and main unit correctly switches between my Blue ray player on Quick Select 2 button, and selects my TiVo box for Quick Select 1 button. And when I press the remote control increase and decrease volume buttons or use the volume dial on the main system, the dB values correctly increase and decrease. What can I try to determine the problem?
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
  • 93 Answers
SOURCE: Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Posted on Nov 06, 2008
  • 163 Answers
SOURCE: Have put an optical cable from optical digital out
You need to do digital input assignment. Go to SETUP, DIGITAL INPUT ASSIGNMENT, set OPTICAL 1 for your input (DVD).
Posted on Apr 09, 2009
  • 1054 Answers
SOURCE: Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Posted on Apr 26, 2013
Power keeps cutting off. stays on for 3 seconds
Could be either a problem with the amp or a bad voltage regulator. Hard to tell without checking some things inside.
Jul 30, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
I have a Denon avr689 and no sound comes out of it??? It worked fine and now it doesn't? My wife hit some buttons on the receiver and hasn't worked again.
Using FM as the test source and turning the volume to something medium, I'd look carefully at the front panel for some indication that Ext In, Muting or a Tape is selected by mistake.
Next, crack the manual and treat it like a new installation. See if the test tones work and go from there.
Feb 02, 2011 | Denon AVR-689 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Dec 22, 2007 | Denon AVR-3806 Receiver
Avr-2802 constantly restarting itself and flickering on and off
check all speaker wires from the receiver end and the speaker ends. Just the smallest strand of copper could be touching something it should not be touching. Make sure all copper is in the speaker post and not hanging out. The receiver is getting a short and shutting off to protect it self. This could have happened since you were just plugging things in.
Jul 29, 2007 | Denon AVR-2802
Denon AVR-689 7.1 Channel Home Theater AV Receiver AVR689 Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
