Question about Honda Electrical Supplies
Honda ep6500cxs how much bulbs it can light up
I have a 1997 Honda Civic 4 door my dash lights are out and the dinging to my headlights is not coming on and I checked every light bulb and every fuse I don't know what to . Is is the dimmer switch
HONDA ILLUMINATION NOT WORKING * HOW TO FIX ...
? 3:24
https://www.youtube.com/watch?v=oOHwDWjmYWU
Feb 28, 2011 - Uploaded by vehix411
No lights,cant see the dash lights,bad bulb,how to change bulb clucter ... i have a 2001 honda civic i installed a new radio andmy cluster lights are ... I just bought the computer or (multiplexer whatever) for my 1997 accord because my back tail lights won't turn on but I ... Martin Nikolov 4 months ago (edited).
Removing a Honda Civic instrument cluster - YouTube
? 4:01
https://www.youtube.com/watch?v=kzp1VqdlmU0
Oct 28, 2012 - Uploaded by mike937739
George L 4 months ago ... I used it to fix my burnt out check engine light bulb in my 97 civic. ... I have no light on my dashboard I already replaced the fuse but still nothing? so I'm ....2005 Civic cluster in 1997 Civic working!
1997 Honda Civic Instrument Panel Lights Problem ...
? 1:26
https://www.youtube.com/watch?v=mYVt93Rao6g
Mar 26, 2013 - Uploaded by fockyoumang
Dec 16, 2015 | Honda Cars & Trucks
Tip
1999 Honda Accord Clock Burnt Out Light Bulb/Lamp Replacement
The Honda OE part number of the Clock Light Bulb2_bing.gif/Lamp replacement is # 35505-S84-N01. The part cost me $3.25 from a local Honda Dealer. A good site with instructions on how to replace the burnt out bulb is http://automotive.trevorated.com/
This part number may work for most G6 / 6th Generation Honda Accords, though I do know it works for my 1999 Honda Accord 4-speed automatic.
on May 07, 2010 | Honda Accord Cars & Trucks
1994 Honda GL 1500 SE Gold Wing dash lights and tail lights do not work
Hi, Anonymous tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
NO REAR TAIL LIGHTS BRAKE OR TURN SIGNAL GL1500 Information Questions...
GL1500 light bulbs
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1500 SE Owner Manual
Feb 23, 2014 | 1994 Honda GL 1500 SE Gold Wing
1984 Honda GL 1200 Aspencade Gold Wing has a short in the tail light
Hi, Joseph tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
gl1200 tail light sensor and electric short
Intermittent short in tail light circuit GL1500 Information Questions...
Honda GL1200D Shop Manual
Honda GL1200 1986 Owner Manual
May 02, 2013 | 1984 Honda GL 1200 Aspencade Gold Wing
How do you replace glove box light in a 1993 Honda Accord
How to replace 95 Honda Accord EX Glove Compartment Box Light Bulb
Mar 07, 2012 | 1993 Honda Accord
Need a diagram on how to replace light bulb in clock in EL Falcon dash.
To replace the clock light bulb on 2001 Honda Accord, you will need:
  • Screwdriver
  • Replacement bulb
  1. Remove the clock assembly in the 2001 Honda accord. Pry the clock assembly off by wedging a flathead screwdriver into the edge and prying off the cover. Work your way around until it comes off.
  2. Remove the old bulb by pulling it out of the socket. Dispose of the bulb.
  3. Replace the bulb with an equivalent bulb. Simply push the bulb into the slot. Be sure to take the bulb with you when you purchase a new bulb so you get the exact bulb. Purchase a bulb with the same voltage. Although a bulb with different voltage may work, it can burn out more quickly.
  4. Replace the clock assembly. Line up the clock assembly over the bulb and press firmly on both edges to attach it back to the 2001 Honda Accord dash.
Tip:
  • Place masking tape on the edges of the dash around the clock assembly to protect your dash while you are removing the assembly with the screwdriver. Remove the masking tape when you are finished replacing the clock light bulb on your 2001 Honda Accord.
Jul 05, 2011 | Falcon 4420
1995 Honda Accord Brake lights not working. Center bulb was burned out. Changed the bulb, now the brake lamp light is on the dashboard and the brakes aren't lighting up
Did u change the bulb w/ the Honda's original BULB? They have a different type BULB in honda, the amperage and the base contact is different from a regular bulb. Hope that helps u out! taah!
Nov 16, 2010 | 1995 Honda Accord
Honda crv 2004 brake lights night lights
LOOK FOR BRAKE LIGHT FUSE OR BURNED OUT BULBS BAD BULB SOCKETS OR GROUNDING PROBLEM.
Feb 24, 2010 | 2004 Honda CR-V
Replace fog light bulb for 2006 Honda Odyssey
Touring Model
Use a wrench to remove the mounting bolt from the underbody through the hole in the splash shield.
Remove the fog light assembly from the bumper by pulling its inner edge first, then the whole assembly out of the bumper.
Remove the electrical connector from the bulb by pushing on the tab and pulling the connector down.
Remove the bulb from the fog light assembly by turning it one quarter turn counterclockwise.
Push the electrical connector onto the new bulb.
Turn on the fog lights to test the new bulb.
Reinstall the fog light assembly into the bumper. Tighten the mounting bolt.
Insert the new bulb into the assembly and turn it one-quarter turn clockwise to lock it in place.
Hope this helps you.
Nov 22, 2009 | 2006 Honda Odyssey
How to change fog lights bulbs on my 2005 honda
  1. Remove the fog light mounting screw.
  2. Disconnect the connector from the fog light.
  3. Turn the socket about 45° counterclockwise and remove it from the housing.
  4. Remove the bulb from the socket.
To Install:
  1. Install the bulb in the socket without touching the glass with bare hands.
  2. Turn the socket about 45° clockwise to install it.
  3. Connect the connector to the fog light.
  4. Install the fog light mounting screw.
Jul 14, 2009 | 2005 Honda Odyssey
Electrical Supplies Logo
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
