Question about Logitech Z3 2 Speakers
Logitech z3 I was trying to connect my lightly used speakers up to my laptop but it seems I'm missing the connecting cord from te speakers to the laptop and I'm not sure exactly what it needs.
  • 108 Answers
SOURCE: Connecting Logitech X-530 speakers to TV flatscreen.
It really depends on what the Tv is capable of, and how you want to strategize the connection, but yes, it can be done.
According to the X-530 User Manual , the speaker system comes with an included video game adapter, for hookup with a console. if your LCD TV has stereo RCA output jacks, you could hook up your speakers to it in that fashion. If not, you may have to buy an adapter that converts whatever you have to RCA.
Another way you could attempt to connect it, is to buy a stereo RCA-to-3.5mm (g9) adapter, and connect to your computer's line in (if it's stereo). Your computer would be doing all the speaker sound positioning, and would have to be left on while you're watching TV, but that would work, as well.
Posted on Jan 01, 2008
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
vikkisuri
  • 46 Answers
SOURCE: How does Logitech X-540 speakers connect to a laptop?
see it is a 5.1 speaker system if your laptop comes with 3 audio jacks with colours green black and pink then all your speakers works if you have only two jacks tht is one jack for audio and other is microfone then u only your woofer and 2 speakers works in speaker cables ther will be two cables connect the green one to green jack your sound plays if u have totally 3 jacks connect the 2nd cable to black one(non microfone jack)check this out this works
Posted on May 09, 2008
SOURCE: logitech z560 set up help
The 4 satilite speakers are all the same. You can get new speaker wire at the local Radio Shck or electronics store. They just recomend an 18 gauge wire. When you wire them the red terminal on the speaker is hooked to the red terminal of the sub woofer speaker. On the back of you volume controller there is a place to plug in the wires from your sound card or motherboard. One cable will do the front speakers and another one will do the rear speakers.
Hope this helps.
Posted on Aug 31, 2008
fixxerss
  • 61 Answers
SOURCE: how to connect Logitech X-540 to a laptop
buy a usb 2.0 type soundcard because your laptop does not support 5.1 surround speaker here is the link that will solve your problem http://www.amazon.com/Zalman-ZM-RSSC-External-Sound-Card/dp/B0001OZ2K8
Posted on Feb 10, 2009
How to connect Logitech R20 speakers to Toshiba laptop?
It may seem odd but connect them to the headphone jack.
Feb 17, 2015 | Logitech R-20 Computer Speakers
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
Hi
http://www.livedigitally.com/2005/09/05/logitech-z-2300-speaker-system/
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Aug 26, 2011 | Logitech Z-2300 Computer Speakers
I was trying to connect my logitech z3 to my laptops music output but it only mutes my computers sound and does not play it. Device is ON. I'm running windows 7 but it shouldn't cause any problems?
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Aug 12, 2011 | Logitech Z3 2 Speakers
Hi I have logitech x-230 speakers which i used on my desktop from the day i bought them i now have a mac laptop and tried using them and they wont work, do i need to download anything to have them work?...
no you dont need to download anything on your mac computer.
there are two ports in mac computer one is for mic and one is for your speakers. make sure your are connecting to the right port.
and please check/change the powerpoint of your speakers.
then check it should work now.
Jun 27, 2011 | Logitech X-230 Computer Speakers
Cable doesn't work - sound out of one speaker
If you need to replace the cable.
try one of these;; I use (and trust!) Monoprice often and Newegg for more specific computer internals..
Never Miss Deal
Computer Parts Laptops Electronics and More Newegg com
Sep 10, 2017 | Logitech V10 Computer Speakers
Speaker stops after a few minutes
I was having the same problem but I seemed to solve it by having the laptop volume maxed and using the dock to control volume. I think that it has a sleep function where if it is not getting a signal it powers off and for some reason the laptop isn't putting out a strong enough signal to keep it awake. Maxing the laptop volume seems to give it a constant enough signal so that the problem went away.
Jan 13, 2009 | Logitech Pure-Fi Anywhere Portable...
Brother tripped over cord connected to laptop
Sounds like the wires inside got pulled loose or broke. Replace the speaker wires or check them good for connection.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 02, 2008 | Logitech Z-2300 2.1 Computer Speaker...
No sound
Sounds like you have missed the wire which connects them to your pc (or to each other)
Mar 21, 2008 | Logitech X-230 Computer Speakers
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Logitech Z3 2 Speakers Logo
42 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
