Question about HP Photosmart C7280 All-in-One Printer
Ink System Failuer Error OxcO5d1381 on hp c7280
Have gotten 2 error Ink System Failure: 1st-Oxc19a0035, 2nd-OxcO5d1381, wireless radio not functioning, turn it off and on and printer does a lot of clicking.
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 21, 2009
  • 685 Answers
SOURCE: HP C5380 WONT OPERATE ANY FUNCTION. ERROR MESSAGE
Here are the instructions for solving that problem on the C5380.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3560275
Posted on Jun 02, 2010
  • 83 Answers
SOURCE: I have an HP scanner/printer,
Its does dry out ,Try some few drops of liquid H2O and put it back but this only to bypass an error. do not try to print.Thank you.
Posted on Sep 12, 2011
Rider On Way
  • 1679 Answers
SOURCE: windows installer error....?
You dont need to do much about this error "Windows installer Error"
There are 2 reasons why this error comes.
1. Your Microsoft Installer file is corrupted or not upto date2. the software you are loading is not updated. you should download the software from web and install.
First Step,
Click on the link and download the latest installer and install it.Windows Installer 4.5
from the website.. download the last file ( name : WindowsXP-KB942288-v3-x86.exe )
Once you have installed this, Click on Start button, Click on RunType " services.msc" and click ok ( without the "")from the list, look for Windows installer and double click on it and click on START button or STOP Button and then START and set the type to Automatically
Step 2
Clear the temporary folder1. Click on Start2. Click on RunIn the window type " %temp%" without the quotes ( just the %temp% ) and click ok.Delete all teh files from the window that comes on the screen. you might not be able to delete few files, so uncheck those files and delete the rest.
Step 3. Download the software for your Printer from the link belowHP Photosmart C7280 AIO Drivers
When you start the installation, uncheck for any HP updates that come up.
This should fix the issue
Regards,Suhail
Posted on May 11, 2012
HP C7280 ink system failure error: 0xc18a0101
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
I hope this help those who have similar issues
Jun 16, 2011 | HP Photosmart C7280 Printer
Ink system failure on my HP C7280
The 'ink system failure' is caused by air in the ink feed tubes. This problem caused by either a poorly refilled ink cartridge or by fully using all of the ink in the cartridge and then the unit sucks up air instead of ink. You will need to purge the air from the ink lines to clear the error. We have a step by step guide posted in an article on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The purge will take about 5 -10 minutes to perform and sould get you back printing.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | HP Photosmart C7280 Laser Printer
HP C7280
Hi there It worth a try nothing to lose and it may work. Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 02, 2010 | HP Photosmart C7280 Laser Printer
Ink system fail. any idea how to solve?
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide to purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 07, 2010 | HP Photosmart C7280 Laser Printer
Ink system failuer
Hi this is kamal here to help u..
just you need to change ur catridge.
regards
kamal singh
Oct 09, 2009 | HP - HP Photosmart 8250 printer
HP 6280 INK SYSTEM FAILURE
Try This :
First check with a new set of orginal HP catridge ; if still it doesn't work then the printer needs to be replaced ; call HP if the printer is in warranty they will do it free of COST ; No. for HP is : 18004746836;
Sep 16, 2009 | HP Photosmart C7280 Printer
HP Photosmart C7280 All-in-One Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
