Question about Audio Technica Audio Players & Recorders
Sound comes out the left speaker very distorted and crackled
  • Amanda Gilmore
    Amanda Gilmore Mar 23, 2015
    I'm having the same issue; I tried switching the pre-amp switch and hear the same problem with the left channel when the switch is in either position. Tested it with multiple albums, and will try a new USB cable as soon as I can pick one up. Thanks.
    Champion:
    New Friend:
  • 215 Answers
Change stylis
Posted on Dec 23, 2014
2 Suggested Answers
SOURCE: Distorted, cracked sound coming through to the speakers
is it possible your new reciever has a built in phono pre-amp?
If so, you need to switch off the pre-amp inside the turntable (lift up the rubber matt, and rotate the plate untill you see the switch at the back)
Try again now?
Posted on Feb 26, 2010
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Speakers are crackling and distorted what size are front speakers for ford cougar 1999
crackling and distortion suggests poor electrical connections. Make sure that the connectors are a tight fit
Jun 08, 2009 | Car Audio & Video
Distorted and crackling sounds
please check sound using external speaker.
if the result is same as using internal speaker, it's mean your mainboard may have problem, but try to install sound driver first.
if the result is different, you may have some loose screews inside your laptop and it stuck on internal speaker.
if you still have warranty, send it to acer.
Apr 12, 2008 | Acer Aspire 5610-4648 Notebook
Polk subwoofer making crackling noises
Yea, now its time to replace it! the magnetic effect is weaken which makes the very bass low frequency sound to be distorted! You should re engergise the magnet of the subwoofer or should buy the new!
Dec 08, 2007 | Infinity BU-120 Subwoofer
Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
May 27, 2006 | Yamaha RX-V496 Receiver
151 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
