Question about Dishwashers
Bosch shu8805uc/u12 beeping signal
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
How do I run a diagnostic test on the Bosch shu5315uc/u12? The cycle time of my dishwasher is at least 4-5 hours.
Long running time on a Bosch dishwasher is almost always a blown solder joint at the heater relay on the control board. You can resolder the joint, replace the relay or replace the control. Control board part number is 00266746.
Jan 13, 2015 | Bosch Dishwashers
I have a Bosch SHU4322uc/u12 dishwasher remove wires from control module, should have taken picture, but did not,need to know where to plug wire into control module thx
Look at the notches in the control and on the wire connections. They are all different and only fit in their own spot.
Dec 30, 2012 | Bosch Dishwashers
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
I have a Bosch dishwasher that is about 4-6 years old (model SHU8805UC/U12). A few days ago I found clear water in the tub hours after the wash cycle had completed. I drained the tub by resetting the...
Just pulled mine out last night. You have a different model but it should be the same. Remove the bottom dress panel and detach your inlet hose from the water valve assembly (have a rag handy to catch a little water). Two torx screws on the front free the the assembly. I had to open my door half way for better clearance and the part (with hose and wires attached) came forward about 3 to 4 inches to allow removal of the 3 wires (1 ground to chassis and 2 hot to the solenoid). The spade lugs were tight to pull off with a needle nose pliers and I scratched my door panel a little so protect it with a rag. Getting the hose off was the hardest as the clamp was hard to release and push back on the hose but a little persistence did the trick. Then I grabbed the assembly in one hand and with a pliers on the hose I could twist it to free it and pull the hose off.
Hope that helps.
Sep 02, 2010 | Dishwashers
My bosch shu3326uc/u12 dishwasher is not getting my dishes as clean as it used to and it doesnt dry plastic at all.
you have changed you detergent?get a good one and you will see the differance.adrian,,,,,,,,,,,,,
Aug 16, 2010 | Bosch Dishwashers
My bosch dishwasher model shu5306 uc/u12 counts down to one minute left then just keeps running
Your d/w has a faulty control board... only solution is to replace it.
Mar 21, 2010 | Bosch Dishwashers
Dishwasher not drying - Bosch Integra SHU9952
Bosch generally drys through evaporation from hot water rinse. There is a common circuit board issue where a cold solder joint on the heater relay pops.The water does not heat sufficient to evaporate any longer. Consult your manual for self diagnosing trouble shooting codes or go to appliance aid.com.
If the board connection is the issue I have repaired several, however Bosch recommends replacement only and sometimes supplies the parts free.
Aug 14, 2008 | Bosch SHU5315UC Dishwasher
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Owen Barnes
