Question about Home
Tub keeps turn back on
While I was in the tub I had turned the jets on and when I was finished using the jets I turned them off. When I did in a few seconds the jets clicked right back on just like I had push the button to turn them on when I had not. I pushed the on/ off button and it went right back off but in just a few second it clicked right back on the like I had turned it on by using the on/ off button again when I had not. The jet kept doing this until I had someone come unplug the system. Could please tell me what could be causing this?
5 Suggested Answers
  • 34 Answers
SOURCE: I pushed the on/off button on my whirlpool tub now stuck
The button is normally an air switch. It is attached to a hose that sends the air pressure from you pressing the switch to a pressure activated switch. This prevents you getting a shock since the wiring is at the motor.
First try using something that vibrates to free it up. Just make sure that it's not something that will scratch the button.
If that doesn't work you should have an access panel to the motor on your tub. Pull this off and look for a clear 1/4" poly tube going into an electrical device. Pull the tube off the pressure switch and blow into it to pop the air switch back up.
Posted on Jun 08, 2010
uspartscente
  • 717 Answers
SOURCE: Our "whirlpool" tub jets do
sounds like it may be either the air button or the air switch (on motor).
pull the pump and plug into an outlet. take a straw and blow into the air switch where the air tubing was connected. If the pump comes on then you know the button. If the pump doesn't come on then you will need to replace the air switch on the back of the motor.
Posted on Feb 08, 2011
  • 17115 Answers
SOURCE: Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Posted on Feb 22, 2013
uspartscente
  • 717 Answers
SOURCE: american standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Posted on Feb 25, 2013
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
May 23, 2010 | NRS Zuma Tub Only - R7236T - Standard
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
Jets shut off...
Most jetted tubs turn off after 20 to 30 minutes. It is a safety feature as well as a thermal protection feature for the motor. I doubt if there is anything wrong with your tub. If you contact the manufacture of the tub, they will most likey confirm what I have said to be what is going on. If it was a hot tub, like the ones used outdoors, this would signify a problem.
Sep 11, 2009 | Home
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Mar 04, 2009 | Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
