Question about Toro LX468 Tractor
Battery fuse location toro lx468
No power at all ,battery good but when I turn key noting,not even a voltage display,is there a fuse
On LX468 Model 13AP61RH848, S/N 18099H10231, the 20A fuse is right under the battery tray. Lift out the battery (under the seat), hold back a little tab, and pull out the tray with a pliers. You should be able to spot the little yellow fuse immediately.
This is totally inconsistent with the text in the Service Manual and Operator's manual which indicate in several places (with pictures even) that the fuse is right near the ignition switch module on the front side (inside) of the dash panel.
On the model and S/N I indicated, the fuse is under the battery.
Posted on May 13, 2014
My Toro SS3200 will not start. No sound when key is turned. No sound when the drive arms are pushed into the parking brake position.
If the main fuse is blown then your not going to get the electric brake to release and it will need to be manually released in order to move the mower even with transaxle place in neutral. Instruction are in the owners manual and if you don't have a copy you can download one from the Toro.com website using your mowers 5 digit model number.
Note: the fuses are located behind the control panel. If 30 amp main fuse or the 25 amp charging fuse is blown then the source of short needs to be found.
Nov 24, 2014 | Toro Garden
Looking for the location of the clutch safety switch on an older toro commercial 11-32
Anytime your engaging blades it pulls quite a bit of juice from the battery, so you need to be absolutely sure your battery is good.
Jul 26, 2014 | Toro Garden
My timecutting z420 won't start. No sound when I turn the key.
check [clean] your battery connections , Charge the battery.
If the battery is older than 5 yrs it may be worn out.
May 10, 2014 | Toro Lawn Mower With Toro Power Tools
HOW DO YOU CLEAR A MAINTENANCE CODE ON A TORO LX468 RIDING MOWER?
Disconnect the battery for ten minutes. this is generally a universal method of clearing codes on electronic control modules. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 24, 2014 | Toro LX468 46" 22-HP Kohler Lawn Tractor
I have an electric start. I charged this today for around 6 hours and there is no engagement what so ever. What should I do? Thanks
I wpold purchase a inexpensive volt/ohm meter or test light and procede to diagnose the problem, first I would make sure your battery did indead take a charge by using volt meter 1 lead to posotive, 1 lead to negative and see if it reads 12.50 or so volts, if that is charged, then if it is a push mower, it has a fuse right inside the battery box/cover by the deck of mower, check to see if you have 12 volts to each side of fuse(you will have to ground the black lead to batt negative black conn. and use red pos. lead to touch the fuse on top should be two bare spots one on each of fuse, if you have power on both sides, fuse is good,if only 1 side,fuse is blown, also check the connectors that fuse sticks in too these have a tendency to corrode and have bad connection,If alls good there I would go to starter and check for power on the heavy red wire when you turn the key to start should light up or show same voltage as battery does. any other questions let me know
Apr 18, 2011 | Toro Lawn Mower With Toro Power Tools
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Replace AC fan motor now car doesnt turn over right away.
You can try this to verify that the starter is good or bad.
Starter Testing Starting System Voltage Drop Tests NOTE: The battery must be in good condition and fully charged prior to performing this test.
There are three area of the starter motor circuits that voltage drop test can be performed on. These include:
  • The starter feed circuit
  • The starter ground circuit
  • The starter solenoid.
Starter Feed Circuit
  1. Disable the fuel system by removing the fuel pump fuse or the fuel pump relay.
  2. Verify that the vehicle will not start.
  3. Connect the positive lead of a voltmeter to the positive terminal of the battery.
  4. Connect the negative lead of a voltmeter to the starter B+ terminal.
  5. Turn the ignition key to the START position and note the voltage displayed on the voltmeter.
    • Ideally, there should be no more than 0.1 volt drop for each connection displayed on the voltmeter. No voltage should be consumed by the vehicle wiring
      1. If the battery cable connects directly to the starter motor there should be no more than a 0.2 volt drop measured
      2. If the vehicle uses a starter solenoid between the battery and the starter motor terminal there should be no more than 0.4 volt displayed on the voltmeter
Starter Ground Circuit
  3. Connect the positive lead of the voltmeter to the case of the starter motor.
  4. Connect the negative lead of the voltmeter to the negative terminal of the battery.
      1. If the battery cable connects directly to the starter motor there should be no more than a 0.2 volt drop measured.
Starter Solenoid
  3. Connect the positive lead of the voltmeter to the case starter B+ terminal.
  4. Connect the negative lead of the voltmeter to the lug (the starter M terminal) that connects the starter solenoid to the starter motor.
    • Ideally, there should be no more than 0.2 volt drop across the starter solenoid displayed on the voltmeter.
In general, there should be no more than a 1.0 volt drop throughout the entire starter motor feed and ground circuit. Any voltage drops measured in either the feed or ground circuits after connections have been cleaned will require replacement of the affected battery cable. Typically, any voltage drops measured in the solenoid are repaired by replacing the starter motor.
I looked at all the steps for replacing the blower motor...they should not have messed with anything that would have affected the operation of the starter.
Apr 02, 2009 | 1999 Toyota Corolla
Toro LX468 Tractor Logo
252 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
