Question about Ovens
EUROTAG OVEN MANUAL - Ovens
F1 error code Kenmore Elite oven I have no owners manual.
Hi.
F1 means defective control module. On manual it will be: "Electronic oven control failure"
From manual:"Replace electronic oven control (also called EOC or clock)."
Try disconnecting power cord or tripping the circuit breaker for a couple of minutes. If the error comes back you will need to replace the oven control module.
Regards.
Ginko
Sep 06, 2011 | Ovens
When I turn on the wall oven it will not heat up, the light doesn't come on
If the oven element or the indicator light don't come on it sounds like a timer problem. I assume the oven has an electronic timer/clock. The timer must be in manual mode for the oven to work. If so, turn the oven ON. Then operate the clock/timer buttons to get it in the manual mode. Be patient. When the oven indicator light comes on it is in manual mode.
Please vote for me if this helps you.
Mar 05, 2011 | Ovens
Bottom oven not working, nothing comes on at all, though the display is flashing AUTO, and cannot change this as do not have manual. Thanks
It sounds like the oven is not working as the electronic timer is in auto. mode. It must be in maunal mode for manual oven operation. Turn the oven on. Muck around with the buttons on the timer and try all different combinations. This may take 5 minutes or more. When you do hit the manual mode the oven indicator light will come on and the oven will work.
Feb 15, 2011 | Ovens
Recently bought this oven (without instruction manual) I cannot get it to start working! When turned on digital display flashes and oven is on auto. How do I set the clock and oven to manual. the oven...
I come across this problem often, particularly with no manual. I turn the oven to ON. I then just muck around with the buttons until I find the manual setting. As soon as you find the manual setting the oven indicator will light. You can normally work it out quickly. But make sure the oven is turned to on whilst you are doing this.
Feb 05, 2011 | Ovens
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
Sep 29, 2009 | Neff U1721 Double circotherm Electric Oven
Lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore ultra bake oven is locked
The manual is located at the back of your oven. If your oven is against a wall, pull it back, not too far, and you will see a manual taped to the back of it. From there, it will provide you with answers some employers won't know. If it's not there, sorry, you're outta luck!
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
223 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
