Question about Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD)
WIRELESS ROUTER HI.... I HAVE A BELKIN WIRELESS ROUTER....WHEN I AM TRYING 2 WATCH A VIDEO ONLINE OR MUSIC IT DOESNT LET ME WATCH THEY FULL THING..... BUT WHEN I PUT THE CONNECTION WITH MY ROADRUNNER CONNECTION IT WORK PERFECT HAVE U EVER COME UPON THIS PROBLEM BEFORE THANKS ALOT JASON.....
  • 2 more comments
  • jason oriol Aug 07, 2007
    Yes I have roadrunner but......when i used the modem that they installed i can watch the whole video but not when i use the belkin router... but i see what ur trying 2 say so what should be the best thing for me 2?
  • rdh39 Dec 12, 2007
    I have a similar problem. With the Belkin connected a large (200 MB +) download will not complete. It actually shows a download speed exceeding 1200mbps at start and gradually getting slower till it stops completely at a speed indicated around 880. Using just the cable modem (no router) speed indicates a high of around 370 and the download completes without any problem.
  • treeclimber Jan 09, 2008
    i have the belkin wireless router when i have it hooked up the connection drops alot videos freeze the whole nine yards wired side and wireless when i run computer without its flawless
  • omar29b Feb 10, 2008
    Unable to watch streaming video using my belkin wireless router. i have a cable internet connection and when i directly attach to the cable modem my computer runs fine hoever as soon as my wirless router is connected i cannot run streamig video it hangs up after 5-10 seconds any one know how to fix this?
    President:
  • 2,961 Answers
If you mean by the roadrunner that you are connect via a cable, the reason why the signal may fail and stop you from watching streamed video is that wireless is only 54mbps and not the best speed for streaming, but wired streams at 100mbps and is constant speed whereas wireless doesnt give a constant true speed of 54mbps it can reduce considerably.
Posted on Aug 06, 2007
  • andrew pester
    andrew pester Aug 07, 2007
    if you wish to stream video it is best using a network cable or a wireless n type router which is 108mbps or 125mbps streaming, but you will also need a supported 108 or125mbps wireless adapter.
SOURCE:
Hi my belkin F7D5301 wireless router light has went from a solid green color to a solid amber color and now i cant connect to the internet unless i bypass the router i have tried resetting the router but...
To remove any problem we must know the reason behind it,
Why Belkin router blinking Orange light:-
1-router is overheating.
2-outdated firmware
3-IP conflict or modem is faulty
4 -the loose connection between router and modem
These are the major issues behind the Belkin router blinking orange.
For Standard, Belkin Troubleshooting read more:-https://bit.ly/2IeAPbI
Troubleshoot your Belkin router blinking orange:-
1-POwer cycle- remove Belkin router from the power outlet wait for 1 min and then plug it back.
2-Connectivity-check all the cables from the modem to the router and make sure they are connected in the right way
3- trying Reset and Re-setup your Belkin router
Hope it will work for you.
Sep 06, 2011 | Belkin Wireless Surf Router (F7D2301)
I have a new Belkin Play router and when I watch a video online (like a you tube video) it pops up and says that my Belkin router password may have changed. It then asks me to re-enter my password and then...
= The Belkin Router Utility Might Not have Been Installed Properly.
> To Get Rid of this Issue 1st of all Disable or Uninstall Belkin Router Utility.
- Goto Start > Control Panel > Uninstall Programs
- Select Belkin Router Manager Utility & Uninstall It.
> Now you Have to Remove preferred Networks & Join the wireless Network.
Steps to Remove Preferred Network & Joining the Network
- Windows XP
- Goto Start > Control Panel > Network Connections > Right Click on Wireless Network Connection > Click on Properties > Select Wireless Networks Tab > Under Preferred Networks Box > Select your Wireless Network Name & Click on Remove Button. Close the window
- Right Click on Wireless Network Connection & Click on View Available wireless Networks.
- Wireless Network Connection window will appear. Select the network you wish to connect and click Connect. It will ask you For a Network Key Type in your Password.
> Windows Vista & Windows 7
- Go to Control Panel > Network and Sharing Center > Click on Manage wireless networks Right click on your wireless Network > Click on Remove Network .
> Connecting to a Wireless Network.
- Goto Network & Sharing Center Click Connect to
- Select your wireless network & click Connect
- It will ask you For a Security Key Type in your Password.
( If you are unable to go online you can try power cycling the router for about 15 seconds. If Even Power cycling doesn't work that means you have to disable WPS option on the Belkin router)
Mar 08, 2011 | Belkin Computers & Internet
Forgot passwrod for a belkin g wireless router - how do I recover it?
In order to find the wireless security password of your Belkin wireless router , please follow these steps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page.
3. In the left hand side, under the heading wireless click on Security
4. It will ask for a password to login, leave the password as blank and click on Submit, then you will be find the wireless security page where you can find your password.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 07, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
I cannot go to my router's network configuration page to find my IP Address top play Xbox Live. How do you access this on a Belkin Wireless G Plus MIMO Router?
type 192.168.2.1 in the address bar of your browser...
it will open the configuration page...
click here for screenshots...
if u have any issues comment back i will be online for next 2 hours...
Nov 29, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
WPA KEY?
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
May 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lost Belkin Wireless G Router F5D7230-4
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 13, 2010 | Belkin (F5D7230-4) Router (587009)
My internet provider doesnt support belkin wireless modem
Let me know the Service provider and the make and model of the previous modem. and also elaborate the problem with belkin.
May 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
G model F5D7230-4 plays music in middle of night! What's up?
Hi Iam wireless router technician
To fix this issue all you have to do is, Make sure that noise is coming from the router first..(If "yes")..Reset the router and re- configure it, Still if you hear the noise..
Confirm the model number( starts with F5D) & version (starts with VER) of your router and cal belkin technical support (toll free number) Explain them the same and you will get free replacement.
Hope this Information helpful for you all
Apr 09, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin n wirelss router setup
Are you Trying to solve this issue?
Just follow the steps
  1. Reboot Your Cable Modem (internet service Provider device) and wait for 30 sec.
  2. Plug the Belkin router to power and Connect the Belkin wireless Router with your modem with help of an Ethernet cable.
  3. Now verify that your WAN port Of modem is Connected to the Yellow Port of your Belkin wireless router.
Read more at How to Setup and Configure Belkin Wireless router TechVaidya
I hope this will help you
Feb 14, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD) Logo
132 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
