Question about Sony Xplod XM-554ZR Car Audio Amplifier
Explode Amp
I hooked my amp up and it started blowing fuses and when i would take out the fuse it would be realy hot. I was woundering if you could tell me why it's doing that.
  • 30 Answers
Is the equiptment used? Your subs may be blown, try disconnecting them from the amp, then power it up, and then see if it still blows fuses. If it does, your subs are either wired incorrectly, or blown.
Posted on Aug 06, 2007
My sony explode amp model xm-sd61x, 300 watt amp blows fuses as soon as i turn it on, I have it opened up, any suggestions
dissconect the speakers from the amp and power the amp up with no load, if it doesn't blow any fuses, check the resistance on the subs with a DMM to see if they are blown
Mar 29, 2010 | Car Audio & Video
Hi Aaron from NZ BLOWING 30 AMP FUSE
Brother you got a dead short was salvage do to wreck if so check inside head light bezel for split or frade wires.
Jan 31, 2009 | 2000 kawasaki VN 1500 Vulcan Classic...
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
Amp is not coming on
the fuse may not be working, you could try a larger sized one, also if you have the old power cable try it again with a larger fuse in place, if it worked before its likely to just be the fuse wasnt big enough, check all the other connections are in the right place, if they all are and you know the amp hase worked before then it could only realy be the fuse isnt big enough or the power lead is faulty.
cheers, adam
Nov 17, 2007 | MTX Thunder TA7801 Car Audio Amplifier
Amp blows fuses "immediately"... HELP
for this to cause a problem with amplifiers there is something internally wrong with it. Most of the time the mosfets take a shit from the hot...cold....hot....cold atmosphere its put in by all of us audio people. If it still has warrenty that would be the easiest route to go. Send it in to them and have them fix it for FREE lol!! well sorta. Hope this helps you understand why you are blowing fuses.
Apr 18, 2007 | Power Acoustik TS1920-2 Car Audio...
My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Feb 23, 2007 | Hifonics BXI 1606D Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
55 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
