Question about Panasonic Nn-sn797s Countertop Microwave Inverter Oven
Microwave door switch - Panasonic Nn-sn797s Countertop Microwave Inverter Oven
Turns on when door is open; turns off when door is shut.
when mine did that it was the door switch had failed
Jan 21, 2016 | In Microwave Ovens
When you close the door, the system will not program , on our kenmore microwave oven. Now it trips the breaker. Why?
I am assuming that closing the door is a key to when the problem arises and will usually lead to a faulty door switch(s). The door switch must be made in order for the microwave safety circuit to be completed and let the microwave know that it is safe to operate. Door switch(s) are one repair worth making on a microwave as most other repairs are not worth the cost of the microwave oven. If you are handy you can check to make sure the switches are closing with a multimeter. Please make sure you have unplugged the microwave before attempting to check the switches. You do not need the power on to verify the closing of the door switch(s).
Aug 14, 2014 | Microwave Ovens
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
The 20 amp power fuse blows every time i start the mircowave oven?
The oven probably has a bad interlock monitor switch, one of several switches in a microwave that are operated by the door latches. The switch is wired so the fuse will blow if you try to run the oven with the door open, and it isn't operating properly when you close the door. As soon as the oven kicks on the power to the magnetron tube, the microwave source, the fuse blows. The switch may have been damaged if the door was slammed, or it's just a mechanical failure. It's not an expensive part, but any microwave repair involving the door should be done by a professional because of safety concerns, so you will have some labor cost to add in. It shouldn't cost as much as a new oven to make this repair, though, so it's probably worth fixing.
Jan 13, 2011 | Hotpoint Microwave Ovens
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Magic Chef MCD1311ST Microwave Oven
Microwave runs when door is opened and is not programmed to run.
Sounds like a defective door switch.  DO NOT USE UNTIL FIXED!!  Or replace the unit.  Microwave ovens have door switches to prevent operation when the door is open because the microwaves are dangerous to humans outside the unit.  The door and cabinet contain the microwaves when it is operating correctly.
May 29, 2009 | Microwave Ovens
Microwave shuts off by itself
The microwave has a safety door switches (2-3 micro switches)
The door mechanism should hit these micro switches. If you can open the machine, you can see that these micro switch has a holder that you can adjust and tighten to make sure that the hook of the door should activate them.
Mar 30, 2017 | Whirlpool GH8155XJ Microwave Oven
MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 05, 2007 | Panasonic NN-S254BF Microwave Oven
Panasonic Nn-sn797s Countertop Microwave Inverter Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
