Why doesn't my zmodo security DVR record? It doesn't recognize the hard drive.
5 Suggested Answers
SOURCE: can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Posted on Mar 16, 2009
  • 375 Answers
SOURCE: Can I get my recordings off a HD DVR with a damaged hard drive?
Sorry, no. Not unless you have a working unit you can put the faulty drive in, but as you say, it's faulty... by its nature a faulty drive isn't useable.
Posted on Aug 20, 2009
  • 56 Answers
SOURCE: I want to record to a external hard drive in order to take to Ira
If you have a dish network system as listed in post a DVR 625 this is NOT possible, it will only work with VIP series Dish Network recivers. and they must be used on teh same model reciever such as Vip 722, tranfer to EXT HD then Watch on another 722!
Posted on Nov 13, 2009
  • 5481 Answers
SOURCE: dvr will not record. i get the message, " hard
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Posted on Oct 14, 2010
We can't get are zmodo to record.
If it was recording OK before i.e. you have had it set up for a while, then the hard drive has failed. It will still give you a picture but not record it.
It is easy to change, just plug a new one in and run the set up routine in the hand book or check it out a Zmodo
Oct 25, 2017 | We Home Security
Why does my zmodo dvr alarm going off
Check the log it could be multiple items causing this problem. Could be over heating, bad hard drive fan failure.
Aug 19, 2014 | Ultra Products Zmodo 4ch Ultra High Res...
Why zmodo cameras lost color
Make sure you have the DVR set to NTSC instead of PAL first. If it is correct then your camera is defective.
Jul 04, 2014 | OEM Systems Zmodo Surveillance...
Not recording
might be your hard drive that is faulty. try to format it and see what happens.
May 12, 2014 | Zmodo 8 Channel H.264 Surveillance...
No video with zmodo DVR-H9118V
I am having the same problem with a zmodo san8, did you ever find an answer?
Dec 08, 2013 | Zmodo 8 Channel Cctv Security Surveillance...
How to hookup audio to home security sys
do you have audio cameras, they don't usually give you the audio cameras with a standard setup, on the back of the dvr there is a plug for audio its either a phono plug or a mic input socket, this can be used in one room or outside depending on the mic you have to buy. you then wire this up to the cctv and have to setup the sound to the camara number.
Jun 24, 2013 | Zmodo dvr-dk41103-1tb cctv 4 ch home...
How to hook up audio
Connect a microphone and enable the audio. It should all be in the settings. Check each camera to make sure audio is enabled. Usually it is off by default.
Zmodo blinking hdd light
A blinking HDD light means it is reading/writing; under normal conditions anyway. Just means that it's being accessed, that's all.
Now if your TV screen is also BLANK, then you have the same problem I do... I'm just waiting on a reply. Mine is the Zmodo ZMD-DX-SBN8 but should be similar enough, I think.
Jan 18, 2012 | OEM Systems Zmodo Surveillance...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
