Question about Garden
Craftsman Briggs and Stratton Tractor model 422707
Looking for the manuel for this model 422707
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 1111 Answers
SOURCE: no power/rough idle/black smoke
either the choke is closed or the float is stuck open..if the float is stuck open, normally it will leak gas
Posted on Jun 23, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman lawn mower. Briggs & Stratton 6.75
1) check plug for being carbon fouled or fuel fouled. Even though it fires, it may not be firing correctly
2) make sure you have compression 75-100 psi. since the compression release so you can pull the rope works off of the exhaust valve, you may not get anymore than that.
3) Is there water or debris in the float bowl
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 26, 2009
Were can I GET a maintence manuel for briggs and stratton ride on lawn mower model nimber 31p777 type number 0296EI
You can go to the Briggs and Stratton web site and to the upper right corner of the page, enter your engine model number, 31p777, when following page comes up scroll down to match with the type number, 0296E1, then you will be able to view all supported materials, this will get you to a screen to download operator's manual and an illustrated parts list.
If you have any more trouble with this just let me know and I will get you straighten out.
If you found this post to be really helpful, please rate four thumbs up.
Jul 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Carb wont pump gas
If gravity feed works to the fuel line on the carburetor, then the fuel pump is bad. Repair or replace fuel pump. I am looking for fuel resistant sealant to repair fuel pump diaphragms. Has anyone tried Permatex 85420 or something else to achieve this? My application is antique and the part is no longer available at a reasonable cost.
May 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
