Question about Watches
Need battery size for relic watch zr15409 - Watches
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
SOURCE: Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Posted on Apr 25, 2008
  • 51 Answers
SOURCE: how to adjust watch band on relic steel watch
OK basically there must be an element that you can push out in the direction of the arrow. Either there is a very thin pin (like a needle) that you can push out with a blunt sewing needle (break the tip), or there is a more sophisticated system as it is shown under the following link:
How to remove links from a watch strap
Cheers
Critter
Posted on Dec 26, 2008
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
Posted on Jan 26, 2009
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Posted on Feb 10, 2009
How do I remove the crown on my RELIC ZR15409 watch?
is this an mechanical watch? all the same open the back and look closely at the area near the crown stem. pull the crown out and see if any little levers move. If they do there may be a little indent on the lever. with the crown in press the indent with a needle and pull the crown our. the also may be a little arrow on the back of the movement pointing at a hole. press a pin in the hole and remove the crown.
Dec 28, 2017 | Relic Watches
Battery size for relic watch. On the back it says ZR11586 then *300210.
Christopher, Neither of these is a battery number. Open the watch and remove the battery. (Gently.) Copy the number(s) on the battery, using a magnifying lens if necessary.
Log onto eBay and search for "[the number] battery". Example: AG10 battery. I've never found one yet that was not available. And they are quite inexpensive--I usually buy more than one.
Apr 03, 2017 | Relic Watches
Battery size for relic watch pr6117
Hi BATTERY for you're watch AG4 1.5 V or 377-377A-LR626-SR626SW. Cheers
Feb 13, 2017 | Relic Watches
I have a relic women's watch ZR 11787 and I need to know what size battery it takes.
Take your watch to a jeweler and have the battery replaced.
Jan 24, 2017 | Relic Watches
What is the battery size relic zr15610?
Take your Relic watch to a jeweler who, for a reasonable sum, will replace the battery.
Dec 03, 2016 | Relic Watches
What size battery goes in a Relic wet ZR15373. Help please
If you don't want to remove the back of the watch yourself, take it to a jewellers shop and ask them to help. They will remove the back, replace the battery and they should give you the number of the battery so you know for next time.
Apr 13, 2015 | Relic Watches
What battery is the replacement? Relic ZR11622
Thank you FixYa.
Look on the back of the watch, or in the manual. If it doesnt say the battery size you will need to take to jeweler to have them measure the compartment to see what battery is needed. Sorry but no other way to know the battery needed.
Best regards. Jewel
Sep 19, 2010 | Relic Wet ZR11657 Watch for Men
Relic Watch Battery
Apr 22, 2008 | Watches
Watches Logo
73 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
