Question about Home Fencing
How do I do a resistance test on an old electro voice T350 vhf driver?
When i turn My Solara DSC VHF radio on it no longer beeps . I cannot hear any squelch or pick up any channels. Is this my speaker that has gone.
To test a speaker, you'll need either a digital multimeter or an analog multimeter that can read measurements of resistance (Ohms)
First isolate the speaker from the amplifier (meaning, remove the wires attached to the speaker terminals).
Set the meter to Ohms (Omega symbol).
Take the meter test leads and place each one on the speaker terminal (make sure the test leads do not touch each other)- there is no polarity to this test so it doesn't matter which test lead goes where on the speaker terminals
For an 8-Ohm rated speaker, you should get a reading of about 6-7 Ohms (approximately 15% of the speaker rating)
For a 4-Ohm speaker, around 2-3 Ohms
and for a 16-Ohm speaker, about 8-Ohms
If you can an infinite reading (make sure the test leads are not touching each other) other wise, if the test leads are not touching and you get an infinite reading, there is a short in the voice coil; speaker is defective.
OL reading on the DMM, or O Ohm resistance on analog meter, broken wire connection inside the coil= open voice coil and is defective.
If you get the proper reading on your speaker, the problem IS NOT with the speaker
Feb 24, 2017 | VHF Boating
I have a 1971 Suzuki t350 bad stator Ideas?
Being a resistive coil there are pass/fail values for that assy. Given it's age, a re-wound unit will restore functionality if that is in fact the failure causing your problem. Find test values, and determine if it is in/out of spec. There are stator rewinders, prices and reputations vary. But it can be done for reasonable money spent. It is also possible to increase the output of the unit when rewound, some can be done some can not for various reasons.
Do a search on stator rewinding, and I believe you will be well on your way to solving your problem.....Good Luck
Sep 09, 2014 | 1971 Suzuki T 350
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Hi my transit van t350 53 plate has went into limp mode after engine change can you tell me what's up
Sorry dealer only to read the software ,unlike the old V4 2.0 litre or the OHC engine .then the good old workhorse with the 2.4 york diesel these vans have become so complicated with the electronics i am at a loss .I remember when these vans first hit the market and they were great for bank robberies as they outran the police noddy cars ,and put a zodiac or capri V6 engine in one ?? with a mkII zodiac diff unit and on the motorway -- well fast
Dec 17, 2013 | Cars & Trucks
How much is the driver and where can i get it from asap
if you hurry this one is $60 http://www.bracesinfo.com/store/Electro-Voice-woofer--EVS-15SF-220697631956.html
or you could go the re-cone route which usually run $70 for that particular driver.
or just run a search on google for EVS15SF the exact driver for the Zx4 cabinet
they are in abundance, a lot of DIYers use them in floor monitors.
Dec 17, 2010 | ElectroVoice Electro-Voice Zx4 15" Passive...
My congregation has a four year old sound system
here is a contact number for the manufacture. 1-800-392-3497
ask for electro voice parts
tell them the model number and make
and a description of the part you need.
Feb 25, 2009 | ElectroVoice Electro Voice HTU2D-767A...
Faulty vhf cb radio
i would suspect a defective audio power amp inside your radio. if you have electronics know how, disconnect the speaker and test with a multimeter for continuity just to be sure. i might just be a dead speaker.. good luck
May 15, 2008 | Radio Communications
Home Fencing Logo
63 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
