Question about Neff Ovens
REMOVE AND REPLACE NEFF OVEN SWITCH U1461N1GB/07
Cant work out how to get old switch shaft out to replace with new one I have bought.
  • 120 Answers
SOURCE: Removal of Zanussi oven door
Hello tracey,
Yes i may be of assistance to your dilemma, if you notice the hinges on the bottom of the door you should be able to open it slightly and gently but firmly pull upwards and outwards which will allow the door to prop off. i would suggest placing the door on either cardboard or a soft rug. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Posted on Nov 26, 2008
SOURCE: how do I switch off child lock from my neff oven 1641
So, you should have a "-s-" being displayed if you have the child lock on.
The switch for selecting the oven mode( oven, fan oven, grill etc)
-from its off position, turn it one click left so the light comes on, and then click it back to off. Do this three times in quick succession. The "-s-" should now have disappeared and you can use your oven again.
Regards,
Steve.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: replacing the element in a NEFF U1721 but having trouble
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
Posted on Jan 16, 2010
barkencoa
  • 3463 Answers
SOURCE: My Neff Main Electric oven does not heat up, the
If the thermostat light is lit, then it cannot be the temp control, as this what is causing the light to work, indicating that the power is there . I f I were you, I would ascertain that you are getting a feed to the element.
If you are, then new element is faulty, if no feed then you need to trace the wires back to thermostat and work from there.
Posted on Jun 06, 2010
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
My oven keeps tripping the electric
It will be the ring element, short circuit. This is the element that runs around the fan behind the backplate in the oven. It can be replaced by isolating from the mains, remove the 4-6 screws hold the backplate on. remove the two screws on the element brabket and one screw holding the element in position at approx 4 o' clock. Be very careful removing the element at the bracket, ease it out very slolwly so as not to detach the spade connector and wiring. A replacement can be obtained from ebay, espares etc or neff direct via there website (link to spares shop). Make sure the wiring goes back on the new element as it came off the old one. Replace screws and backplate and it should be sorted.
Hope this helps
Apr 03, 2013 | Neff B1421 Electric Single Oven
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
How to replace knobs on u1661 oven
Just pull them off and replace. Its that simple.
Apr 27, 2012 | Neff U1661 Double circotherm super...
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
Please help Fan not working in Neff U1451
Hi, the fan is one part and the bulb another. They are not connected. If the bulb isn't working simply unscrew the bulb lens and replace the bulb. About the fan motor, sometimes they cease up because the build up of grease at the back of the oven. You can try to remove the insid back plate that covers the element and fan, and try to rotate the fan manually. Try to clean it and test again. Last resource, it needs a new fan motor.
Cheers
Feb 08, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
How do I replace the heating element in Neff U1461N2 main oven?
Switch power off first.
Remove the screws that secure the rear cover in the oven compartment.
There you will see the circular element, undo screws that secure element, slówly withdraw element towards you, disconnect leads, taking care not to lose them behind the aperture., fit leads onto new element, and refit element.
Refit cover and test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
22 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
