Question about HP LaserJet Office Equipment & Supplies
How to create Scan shortcut in hp laserjet m1005
Nic61
  • 1073 Answers
SOURCE: i'm looking for a driver for hp laserjet m1005 mfp
Hi Oye!
Here is all avalible drivers for your HP M1005 MFP
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&submit.y=4&submit.x=9&lang=en&cc=us
Select the OS you running and download the drivers you need
Good luck
Nic
Posted on Aug 12, 2009
ajuhere81
  • 256 Answers
SOURCE: hp laserjet m1005 mfp printer, but it's cd was crack
You can downlaod the original drivers and software from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1839459&prodTypeId=18972&prodSeriesId=1839458&swLang=8&taskId=135&swEnvOID=228
Posted on Aug 29, 2009
seeker5211
  • 1089 Answers
SOURCE: HP Laserjet M1005 MFP scanner and printer shows
The job that you are trying to print is too complex for the printer. Add more memory. Or simplify the job.
Posted on May 17, 2010
  • 31 Answers
SOURCE: How do I scan a document on a HP Laserjet m1522nf...
install full software, download from www.hp.com
Posted on Aug 10, 2010
SOURCE: i am not able to use the scanning facility of hp
You can do it using Image Capture. First uninstall HP software, then with the printer turned on open Image Capture. Under Divices click Browse Divices then select Enable Twain (for your m1005).
Posted on Sep 07, 2010
Hp laserjet m1005 scaner error 20
Scan head drive mechanism faulty., Follow the snaps chk for breakages.,
Replace new part if its available, If not alter the part as shown in snaps..( ex:which I did early)
Feb 26, 2015 | HP LaserJet M1005 Printer
Tip
HP M1005 "Scan To" has disappeard in windows 7 - SOLVED
When I migrated to Windows 7 and installed the printer driver, the Scan To function disappeared.<br /> <br /> I then found a firmware upgrade located at<br /> <a href="http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1839458&prodNameId=1839459&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-43456-3">http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1839458&prodNameId=1839459&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-43456-3</a><br /> <br /> Download M1005_FW_Update-20070302.exe (2.4 MB) and run the upgrade.<br /> <br /> Then you press Windows Start, select Devices & Printers.<br /> Then when the printers are shown, right click on the HP LaserJet M1005 and you will find the new scan options appear.
on Mar 20, 2011 | HP LaserJet M1005 All-In-One Printer
Loss my drivers for HP Laserjet M1005 mfp
If you go to H.P's website and go to support imput that you need drivers for your laserjet m1005 mfp. and you will either be able to down load it right away or they will send you an e-mail with it or a link to retrieve one..Good Luck
Nov 15, 2012 | HP LaserJet M1005 Printer
Hp lj m1005 scanner error 6
Scan head faulty & it need to replace to solve this issue...Scan head located under flat bed glass, to remove this part flat bed unit need to open..see the snap shot.5_25_2012_7_09_54_pm.jpg
May 25, 2012 | HP LaserJet M1005 Printer
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
Hp laser jet m1005 scanner error 20 cud u tell me what is the problem
Open flat bed glass, remove scan head(which part is moving right & left having light)check driving mechanism any breakage/warn out replace mechanism if its good replace scan head..see the snapshot idle scan head mechanism breakage areas for observation.
Oct 06, 2011 | HP LaserJet M1005 Printer
My HP LaserJet M1005 Printer show Scanner error 12 and not work any copy print scan please choose a solvation
Remove: Operation panel, flat bed glass & scan head. Observe scan head mechanism drive gear placing pinion, if its broken replace the driver gear mechanism, if it is not available, make a metal pinion & fix there, but if you fails in first attempt, no second chance. Bee careful..best of luck...
Sep 26, 2011 | HP LaserJet M1005 Printer
Scan in pdf format in HP M 1005
To Scan and create PDF document You need to install a PDF writer program first. There arequite a few freeware PDF writer programs on the Internet you can download onesuch as CutePDF.
Scan your document the click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Feb 26, 2011 | HP LaserJet M1005 Printer
I have hpm1005-mfp printer and want to install the same in my laptop having windows -7-64 bit OS.I have downloaded the same from hp driver site.Printer is working but i am not able to use scanner in the...
Maybe the software that was installed is not the correct one for the all in one .So check the HP site once again and see if there is a new link to get your software or post a query to them .
Sep 28, 2010 | HP LaserJet M1005 All-In-One Printer
235 people viewed this question
Seeker5211
Seeker5211
