Question about Xerox WorkCentre 7232 7242 220v Fuser Cartridge 008R13045
WorkCentre 7232/7242 disable banner sheet - Xerox WorkCentre 7232 7242 220v Fuser Cartridge 008R13045
How do I stop the test page from ALWAYS printing from my WorkCentre 7120 printer?
If I am not wrong you are asking about Banner Sheet? I guess. close all your open applications and go to Device and printers, then right click on the 7120 printer and select printing preferences, then go to advanced Tab. select + next to Paper / output. you will see (print ID on Banner Sheet) select it and go for the option Disable job ID. make your changes save by pressing ok.
Apr 07, 2014 | Xerox WorkCentre 7120/P Printer
I cannot use cover pages with my workcentre Xerox 7328 since i got windows 7
update your print driver to latest version and make sure you select Win 7 (32 or 64 bit) as OS if not already selected. once loaded, rt-click on printer, select Print Prefs, goto Advanced Tab, expand Paper selection and Enable Banner Page.
Jun 10, 2011 | Xerox WorkCentre 7328 Multifunction laser...
We have 2 minor problems we are trying to solve
I am going to have to send your answer in multiple parts since the procedures are lengthy, You have to turn the banner sheet off on BOTH the machine and driver. The procedures you need will follow. In several parts. Sounds top secret doesnt it LOL....
How to disable it on the machine.
  1. Press the [Access] button (key symbol) on the Control Panel. The System Administrator - Password Entry screen will be displayed on the Touch Screen.
  2. Enter the administrator password using the numeric keypad on the Control Panel, and then select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE: The default password is 11111. Your password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. If you want to cancel the operation, select [Cancel]. If the administrator encounters a problem with changing the access code, or forgets the code, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Print Mode Settings].
  6. Select [Others].
  7. Select the [Banner Sheet] (option 3).
  8. Select [Change Settings]. A list of options will be displayed.
  9. Select [Off] to disable the Banner Sheet.
  10. Select [Save].
  11. Select [Close] three times.
  12. Select [Exit] to exit.
Feb 27, 2009 | Xerox WorkCentre M-24 Color Copier
Default page
You did not list the model number, but usually you go to Start>Settings>Printers and Faxes and right click on the Xerox Printer and choose properties. Go to the ADVANCED tab and choose Printing Defaults. Now look at the Advanced tab in this window and select Paper/Output. Look for Banner sheet and choose disable. Apply and save and exit.
Nov 05, 2008 | HP Photosmart C7280 Laser Printer
Turning off job headers
You have to turn that off , it is called a banner Page, I will sent you a few ways of disabling it.
When enabled, the Banner Page prints for each job. The Banner Page consists of the following:
  • Username
  • Job Name
  • Date
  • Time
  1. From the WorkCentre, enter the Tools mode. See the Related Items below for additional information. The Tools Mode screen will be displayed.
  2. Select [System Settings] from the Touch Screen. The System Settings screen will be displayed.
    NOTE: Depending on the model and configuration, there will either be 2 or 3 main screens available in System Settings. For example, the initial screen will be noted as System Settings screen 1 of 2 or 1 of 3.
  3. Select the [Job Sheets] button. The Job Sheets screen will be displayed.
  4. Select the [Banner Sheets] button. The Banner Sheets screen will be displayed.
  5. Select [Enabled] or [Disabled].
  6. Select [Save].
  7. Select [Exit Tools].
Oh yeah
How to enter tools mode would help huh LOL
NOTE: The Tools mode is password protected. The factory set default password is 1111. It is recommended to modify the default password. See the Related Items below for additional information. The Administrator (Tools mode) password used to enter the Tools mode directly at the WorkCentre and the CWIS Administrator password are the same password. If one is modified, it affects the other.
Oct 18, 2008 | Xerox WorkCentre 4150 Black and White...
How can I avoid printing a cover sheet every time we print on a 265 st xerox document center
You have to enter the customer settings, access button then 11111. Scroll around until you find the location to turn OFF the cover sheets.
You also MUST have cover sheets disables on ALL conputers connected to the machine. Somehow if someone on the network has the cover sheet turned on, it will sometimes enable it on the machine also.
It is called BANNER sheet in the memory.
Jul 15, 2008 | Xerox Document Centre 265ST Printer
Printing issue..please help
That sounds like a banner sheet, in your menus, Specifically a print menu you will find a section with reports, it should be caled banner sheet.
They may have another name for it. But disable that. Also go ont the driver on your computer and look to turn the banner sheet off.
Some call it a print acrivity sheet also.
make sure those pages are turned off on both the printer and on the print driver on the computer.
Feb 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Xerox WorkCentre 7232 7242 220v Fuser Cartridge 008R13045 Logo
149 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
