Question about Garden
Honda hydrostatic 1211 starting problems
Mower will not start after tilting over to free rotor cutter blade- some oil has leaked out. Help please! Could the spark plug have got wet?
  • 79 Answers
SOURCE: push rod loose
Hi
Very possible that the valve is stuck open and piston could have hit valve causing it to bend at the head. This would cause valve not to close completely. Would have to remove head and remove valve and most likely replace intake valve.
Posted on Apr 09, 2009
  • 64 Answers
SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Posted on Aug 23, 2009
  • 24 Answers
SOURCE: Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
  • 4088 Answers
SOURCE: i recently change the blade
Make sure the air filter is not plugged with oil. Remove the spark plug (gapped 0.020") and check for spark--it should be blue and snappy. Squirt some fuel or starting fluid in the plug hole and try for start. If it pops several times, check the carburetor and fuel supply. There is likely to be considerable smoke when it does start, but that will quit. Hope this helps!
Posted on Aug 05, 2010
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
Honda HR215 PXA recoil start is locked up after replacing the mower blade. No obstructions.
pull the plug and allow the excess fuel or oil to be removed
tilting the mower to access the blades has allowed fuel or oil to enter the combustion chamber
Sep 09, 2017 | Honda Garden
Vita 35 classic lawn mower not starting after tilting 2 change blades.
Use some staring fluid to get it going and that will burn off the oil.
Sep 04, 2016 | Garden
2004 jd 790when l push the clutch pedal all the way down you can not engage the PTO in without it grinding.this happens only with rotary mower cutter tractor 3 point.with another attachment works fine
How to Troubleshoot Riding Lawnmower Problems When it is time to mow the lawn, and the old, faithful lawnmower just doesn't want to get the job done, you may need to do some maintenance or repair on the machine. Here are some steps to guide you in troubleshooting a few common problems.
Steps 1.Check the basic mower functions to determine where you need to look to diagnose the problem you are having with your mower. Here are the basic parts of a typical mower:
  • Engine
  • Belts and pulleys
  • Mower deck
  • Wheels and axle assemblies
  • Blades
  • Transmission/drive system
  • Safety system
2. Check each part of the mower to make sure it is working. First, you must make sure the engine is running. This should be obvious, and no other part of the machine will work if the engine won't start. Here is a checklist to get started diagnosing engine problems.
  1. Check the crankcase lubricant (motor oil). Many modern engines have an oil sensor that shuts off the engine if the oil level is too low for it to operate safely.
  2. Check the fuel. You may want to check the fuel pump, filter, and fuel lines for leaks or blockages.
  3. Check the air filter. Dirty air filters rob the engine's performance, and if the filter is sufficiently stopped up, it will not allow it to crank.
  4. Check the carburetor. Make sure all linkages and attachment bolts/screws are tight.
  5. Check the starting system if the mower is equipped with electric start. This includes the battery, battery cables, solenoid switch, ignition switch, starter motor, and neutral switch if equipped.
3. Check the drive belt system if the mower doesn't move or the blades will not rotate when they are engaged. This can be done by lowering the mower deck and removing any debris that obstructs your view. Here are some things you will be looking for:
  • The main drive belts should go from a pulley on the bottom of the engine to the mower deck drive pulley and to the transmission/transaxle. These should be tight when they are engaged, and loose when the clutch is depressed (transmission drive belt), and when the mower is disengaged (mower deck drive belt). Obvious things to look for are damaged or broken belts, or loose pulleys.
  1. Check wiring to the electric mower drive clutch if the machine is equipped with one.
  2. Check linkages that operate the belt idler pulleys and transmission shifter.
4. Check the lubricant in the transaxle when the mower is serviced. The bearings and gears in lawnmower transaxles will quickly become damaged if they do not receive sufficient lubrication.
5. Check the tires and axles if the mower seems underpowered or the steering doesn't seem to be operating properly. Front wheels often have grease fittings that extend the life of the wheel bearings or bushings, and when these are worn excessively, steering will operate well.
6. Keep your mower's blades sharp and balanced. This not only provides a better cut, but also decreases wear and tear on the machine. Here are things to look for to spot problems with the blades.
  • Uneven or ragged cutting is often a sign of worn, dull, or bent blades.
  • Vibration underneath the mower deck can indicate blades which are out of balance (or damaged spindles on the blade carriers) and should be repaired promptly.
another source that might help is:
Lawn Mower Repair Help
WelcomeLawnmower Man FREE Lawn Mower andSmall Engine Repair Help
Jul 02, 2015 | Garden
How do I fix a drive belt to a honda 1211 hydrostatic lawn mower please?
What you should do is take your mower to Home Depot and see if they can help you out.
Apr 28, 2015 | Garden
Why does mower cut out when cutter blade selected?
this is posted is cell phone section. unless cell phones cut grass now this is a miracle. please change catagory and please add make and model of mower.
Apr 25, 2014 | Huawei Cell Phones
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Type your problem for a solution...mowing for 10 minintes stoped to ceck blades started mower blue smokeout exhust. stoped mower checked oil will not start checked plug ,filter carbie and control lever
to check blade you tilted the mower and got oil where it should not be.
exhaust will clear out, check all controls to see if the spark is still there, allso a compression test check out a lot of problems. if it is low ,under 60 ,
just check the basic the three things needed to run- compression,spark,and fuel. always check things with the spark plug wire pulled of the spark plug. good luck
Jan 03, 2012 | Garden
Husqvarna_24hp_54_yard_tractor
when was the last time you took a look at the cutter blades,,or serviced the cutter deck? if the cutting blades are blunt or rounded off it will stall the engine stress the belts and the clutch,,,also if the mower has been standing un ran all winter it may have "rust" on the engine valves,,running the engine unloaded for a time may knock this off but under load the compreshion is pushed up into the inlet and pops back through the carb,,,try putting into the fule a little "two stroke oil" only 5cc a gall no more! this will lube the velves and carb,,,but sharpen them cutter blades up first,,,or its like trying to eat a half cooked stake with a blunt knife and no teeth? that reminds me? were have my teeth gone?
Jul 31, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Won't start
the blades may be locked. remove the spark plug cap so the mower won't start unexpectedly. tilt the mower on its side, air filter facing upwards. work the blades until they loosen and turn freely.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
