Question about Matrix Televison & Video
Mx- tvs1484 remote contol is been lock
What is remote control code from mx-tvs1484
0275,0277. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Nov 07, 2014 | Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Need codes to add components to master control, I would like to add my cd player to master remote contol, reason cd unit has no remote
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 06, 2010 | Sony STR-DG510 Receiver
Matherbord
http://support.asus.com/download/download_item.aspx?product=1&model=P4GE-MX
Aug 24, 2009 | ASUS P4GE-MX Motherboard
Where can I purchase a Lithium battery 046067 for an MX 3000?
Do you favorite search engine and type your model number and then batteries. What I got is www.buy.com
Aug 18, 2009 | Universal Remote Control MX-3000 LCD...
Mx 3000 screen is locked -does not respond when taken from charge
Take out the battery and reboot, or press and hold main for 10 seconds and reset to factory settings. If that does not work I can help you with more testing. Visit my site (www.totalcontrolremotes.com) and I will help.
Regards,
Vincent
Jan 17, 2009 | Universal Remote Control MX-3000 LCD...
Drivers door controls quit working
wires or plug where they pass from body to door in a big rubber sheaf
Oct 02, 2008 | 2001 Volvo S80
Power door locks do not work at all lights flash when remote is used to unlock doors. automatic lock feature does not work Once manually unlocked, sliding side doors work ok. tail gate can be used to opens...
the reason the locks dont work more then likely there is a code stored in the bcm for a lock output circuit normally caused by one if not both of the sliding door acuators. even if you change the acuators the locks still will not work until the code is cleared.
Sep 14, 2008 | 2000 Dodge Grand Caravan
UNLOCKING THE FRONT LOCK CONTROL
hold it in and it will change. mike
Aug 15, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
Top Matrix Televison & Video Experts
Electro Med Services...
Are you a Matrix Televison and Video Expert? Answer questions, earn points and help others
