Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT47-wx49 My 47in panasonic tv will play for about 45 min or so then powers itself off,the only way to get it back on is to unplug it.I have talked to a repair person and he said to hit it on the sides to wake up the sleeping componets,and that the problem is in componet marked Q406 and one of the leads needs resoldered.Has anyone herd of this,and help me find it.
  • Anonymous Feb 28, 2008
    Comes on for 3 seconds then shuts off. Have to unplug and the same thing happens again
  • josh 1 Feb 28, 2008
    comes on for 3 seconds and then shuts off. Have to unplug and it happens again.
  • 126 Answers
Well sound like the reair tec. is right but don't just look for that area scan and resolder the whole board for open cold solder joints
Posted on Feb 17, 2008
SOURCE:
Panasonic pt52lcx15 TV. Recently, after approximately 5 min. The TV turns off. Is this some sort of power supply issue? Or, something else?
Try this.
Unplug the tv. take off the back panel. vacuum or blow out the dust with a can of compressed air (@ $3 at Staples). A lot of the projection tvs had a thermal sensor which would turn the tv off if it got to hot.
That is also a good time to clean the lenses. Be careful not to move them out of alignment. My tv worked like new after I did those things.
Jun 10, 2015 | Panasonic Televison & Video
Tv turned off while i was playing xbox 360.
well I had same problem about my 65" Samsung tv some ware I read to check small capacitor. I open back panel n find few capacitor burn out n replace it n work fine u can find those capacitor from radio sake for about $1.99 each good luck...
Mar 29, 2014 | Panasonic Viera TC-P50S1
Panasonic 42 tcp42x3 plasma tv turns off after 5 minutes solid red ligh no blinking will turn back on if I unplug and plug back in but off in 5 mins again
The fact if unplugged etc and tries to function means a micro related problem---if unplugging all units for a while does not change this then suspect a power supply or main board (controls all functions).
Oct 15, 2012 | Panasonic 42 TCP42X3 42 Plasma TV
TV will not turn on. Problem with the Panasonic
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same result.Mean ur tv power supply board have problems and the causes.That the board,where the power a/c plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 19, 2011 | Panasonic TCP42G25 42 in. TV
Tv not turning on
You can try leaving the TV unplugged for 30 - 45 mintues so the TV discharge and reset itself.
If this doesn't work, the TV may have just a blown fuse inside that just needs replacing. Or, it's going to be a power supply board related problem.
Aug 07, 2009 | Panasonic TH-42PZ77U TV
Panasonic projection hdtv
My panasonic projection tv's converge does not get fixed. does any one has solution.
Jul 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Turns on and immediately shuts off
check for sleep mode and whether the timer for sleep mode is on or not, if sleep mode is on lets say 30 min or 5 min , ur TV will turn off automatically after that much time
Dec 16, 2007 | Panasonic CT-32HX42 32" TV
Information
http://www.devicemanuals.com/guide/Television/Panasonic/Panasonic-PT47WX49E-47-PROJECTION-TV-TkRJeU13PT.html
Dec 10, 2007 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
