Question about Saws
Macallister mitre saw instructions
Wher is the blade unlocking mechanism so that the blade ca be lifted
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
VtToolMan
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do you replace the blade on as Protech 8 1/4
there should be a spindle lock on the opposite side of the blade bolt,, make sure that when you replace the blade that you install the flanges correctly and if there a spacer that it is in place.
Posted on Dec 22, 2009
puertobori
  • 7733 Answers
SOURCE: blade guard for Ryobi 254mm Slide Compound Mitre
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
SOURCE: how do I change the blade on mastercraft compound mitre saw
I have the same question.
Posted on Apr 17, 2011
Replacing blade guard on a 1700W sliding mitre saw
There is an upper (fixed) blade guard and a lower (moving) blade guard which has the added complication of being connected to a linkage or mechanism to swivel the guard away from the workpiece as it approaches the cut.
Mostly careful inspection, once the blade has been removed, will show removal of the guards to be a faily intuitive process. It is inevitable some makes of saw will be more complex and in the absence of official detailed instructions, it will mean a process of removing clips and screws until the part falls off and then remembering what you did so you can put it back together with no parts left over.
Jun 12, 2016 | Saws
Saw do not lift when turned over
Is this the saw you are talking about? A compound mitre saw?
TFO 250 Ryobi
I'm assuming you cannot lift the blade up by the handle without the whole saw coming with it. That usually means that the saw is locking into place for transportation purposes. Look at the pictures below and see if the lock pin in engaged.
Apr 19, 2015 | Ryobi Saws
HOW DO I CHANGE THE BLADE ON A 36-070C MITRE SAW
Not sure about the Delta. I've had both a Craftsman and a Dewalt. On both of those, the pivoting plastic guard pivots on a plate on the side of the metal guard. The plate isnt easy to see. You rotate the plastic guard all the way open and you see the edge of the plate held in place by a screw. Remove the screw and the plastic guard and the hub along with the plate it's mounted on can lift up an half inch or so--far enough to get the blade screw off the arbor.
There's a push button somewhere that locks the blade from turning so you can turn the screw in the center of the arbor with a wrench.
Sep 16, 2014 | Saws
Macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Feb 26, 2012 | Saws
Can't find the lock catch to lift the blade
It going to be on the right side as you look at the machine, because most people are right handed. Push down on the saw body to see if there is any movement and then look for the stop.
Sep 16, 2009 | Delta 79 803 3' Miter Table System
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
My mitre saw wont lift up into the cutting position it seems stuk
look on the left side of the saw just past the blade there is a knob there pull it out as you hang onto the handle of the saw ,the knob is spring loaded,plus the if you dont hold onto the handle the unit will come up very fast.possible of hurting you or the saw.
Mar 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
