Printer hp f1485
Attention button continously blinks i can't print any document after check the cartridge and reset too
SOURCE: Printing trouble with HP Deskjet 3845
driver hp deskjet 3845
Posted on Jan 16, 2008
SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
  • http://www.misterinkjet.com/hpreset.htm Scroll down and you will find links to pages for the #56 & #57 cartridge serial number reset procedure.
  • If the above doesn't resolve your problem, try removing both cartridges, then - with the printer still turned "ON", unplug the power supply cord from the back of the machine. After one minute has passed, press down and hold both the "#" button and the "6" button on the keypad and while pressing those buttons, reach back and plug the power cord back into the machine. The LED readout will indicate "Initializing" and "Reset..." Then, release the "#" and "6" buttons and wait until the machine re-initializes and prompts you to install ink cartridges. Reinstall the cartridges and see if the problem is resolved. The reset procedure, as well as other troubleshooting procedures (paper jams, ink cartridge jams, etc.) can be found here, on the HP support pages.
  • Another way of working around the cartridge error problem is to keep at least 3 sets of cartridges on hand, using the newest sets for re-filling. You may have to switch out 2 or 3 times just to get the machine's memory maxed out, but the third set should work. This particular method works best with OEM HP cartridges, but I've heard it works with other brands, too.
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
Posted on Mar 17, 2008
Joed911
  • 4338 Answers
SOURCE: hp psc 1500 constnatly blinks check printer cartridge and does no
According to this HP document, the problem is with the ink cartridge(s):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308379&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You may want to try a reset:
Reset the HP All-in-One Follow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 23, 2008
SOURCE: Print Cartridge Problem- HP PSC 1513
My print cartridge problem was finaly solved by replacing the power supply cord!!!
It was found that the supply connector at the back of the printer did not have good enough
contact which caused the printer to fail during powerup (during powerup it drows more power when
it turns on the morots...).
Posted on Feb 28, 2009
  • 73 Answers
SOURCE: HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Posted on Apr 14, 2009
It is showing a triangle with excalamtion mark blinking
That would be the attention light.... Indicates that the input tray is empty, the print- cartridge door is open, or bad toner. Is there any lights that are on solid or flashing? (could also have a bad fuser ... need to trouble shoot this a little more)
If you hit the green button does it do anything?
- www.trusttechnology.biz
Mar 13, 2014 | HP LaserJet 1320 Printer
I have problem that on my hp 1220 deskjet ar blinking all of buttons. I mean buttons for power, buttons for parer and button for cartrige and don't printing anything. How can I fix this?
Hi, This is the problem of cartridge mostly. You may need to replace the cartridges. Check the cartridges and make sure that the cartridges are not blank or not get the ink dry. Clean the printing head 2-3 times. Align the cartridges and clean the nozzles also. Reset your printer and remove all pending print job. If it doesn't solve your problem then replace the cartridges.
Sep 26, 2011 | HP DeskJet 1220c InkJet Printer
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Green light working continously
It might be you change your cartridge to that and you did not insert it properly so that they blink. Try to check the cartridge if it can insert properly then restart your printer and try to print it again. If they are blinking again just press the reset button or turned off your printer then turned it on again and try to print.
May 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Hp psc 1500 constnatly blinks check printer cartridge and does no
Thanks, Joe
Nov 22, 2008 | Office Equipment & Supplies
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
jasbo
jasbo
