Question about Garden
Wolfgarten strimmer Spool line keeps breaking
SOURCE: BD GL720 strimmer
Yes it can be repaired Jim. The belt has probably snapped. It happened on mine. Just undo all the screws and one hidden screw underneath the black lable near the number one, which is on the same side as all the other screws. Run your finger over the lable and you should feel it. Just pull the telescopic arm out and lift up the motor slightly so that you can place a new belt on. Simple as. Hope this helps
Posted on Jul 15, 2008
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
  • 22 Answers
SOURCE: Strimmer line replacement
what model do you have?
Posted on Apr 03, 2009
  • 8 Answers
SOURCE: strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Posted on Sep 13, 2009
al_kupchella
  • 843 Answers
SOURCE: I have a Micky Mouse of a Black and Decker grass
Sounds like you may have lost the little metal grommet that should surround the hole that the business end of the string comes through. This grommet is usually aluminum because it is a very good heat conductor. What happens is that the string rubs very hard against the edge of this hole, which heats up the string in that one little spot enough to melt it. If the hole is only plastic, it cannot dissipate this heat. The grommet dissipates that heat and the string doesn't melt. I don't know if you can buy a replacement grommet. You might be able to a generic grommet like the kind sold for tarps. Or you can replace the whole part that should have the grommet in it.
Posted on May 25, 2010
Restring a pgt300 performance power strimmer, it has a white casing which does not come off preventing me from adding more line
There should be 2 plastic tabs which you have to push in, this removes the wider outer base cover of the strimmer spool, giving you access to the bump cap and line spool.
Depending on the style you have, one looks to be a whole replaceable spool unit, one looks like a re-threadable spool.
If you find this useful, please click the 'helpful' tab. Thank you
May 14, 2016 | Garden
Why is a replacement spool and line not available for Qualcast GGT4502? Its only 7 months old (from Homebase) !!!
I think it's because Homebase no longer sell them. It's really annoying - I bought the last replacement spool that they had a couple of weeks ago for the strimmer I bought last summer.
After this is used, I'll have to buy a new strimmer. Bad judgement there, Homebase.
Apr 15, 2011 | Garden
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
Strimmer cord keeps breaking
Sep 01, 2009 | Garden
How do you change the cord on a b and d strimmer
Hi, W/D here.
Pull the spool straight off, out of the head. Look at the bottom of the spool, you'll see arrows indicating the direction that the line should be wound. Now, look at the spool. You'll see that there are actually two spools, made together. In the middle part of each spool, you'll see a small hole. There should also be a notch in between the two spools.
OK. Starting with the inner spool, insert your line into the hole about 1/8", and wind in the direction of the arrows. When you have wound the line to the diameter of the divider between the spools, stop. There is a very small notch on the bottom of the spools that is 180 degrees from the notch in between the spools, and at the bottom edge of the spool that you are winding. Click your line into that notch. Leave about 6" of line out past the notch, and cut it off from the pack of line that you are winding from. Now, wind the outer spool the same way. When full, you'll guide your line thru the notch between the spools and into the small notch at the bottom of the inner spool. Leave another 6" tail, and cut it off.
Take the two tails of line while holding the spool,and insert one into each grommet on the machine head. Align the line notches with the grommets, and press the spool into place. You should feel it click into place. Now, you want to tug on the line tails to pull them out of the notches. You're done!
I have one final bit of advice, and you don't have to do it this time...just keep it in mind... The head will sometimes be stubborn in dispensing the line. I find that occasionally putting a little graphite into the hole where tha spool fits onto the machine helps the line advance part work much smoother, and it keeps the head from sticking.
Best regards, --W/D--
Aug 14, 2009 | Black & Decker Garden
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 | Garden
Gls 220 auto strimmer
When putting new line on, it must be wound clockwise onto the spool
Jim
Jun 30, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
How do you fit the nylon line to the strimmer part.is there a diagram or a video somewhere.my line keeps coming out everytime i turn it on.thanks
try taking off the spool at the end of the trimmer and wineing the line around the spool and putting the spool back on the end of the trimmer
Apr 06, 2009 | Garden
How can i repace the line on a black & decker strimmer gl550
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Apr 20, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
