Super general dear sir, i have a super general washing machine having model sgw 6100 and it is not going to start as we have lost our mannual so we could not find the meaning of error. as it is showing EI and not going to start, could you please send me a soft copy for trouble shoot or guide how to solve the problem. thanks daud
tunde007
  • 2382 Answers
SOURCE: Gd evng Sir. I am Krish.
Hi, in other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probably that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles and removing it should solve the problem....
Posted on Dec 09, 2010
huuum
  • 750 Answers
SOURCE: Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Posted on Dec 07, 2008
  • 6277 Answers
SOURCE: Hi friends, I have Panasonic
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
  • 6277 Answers
SOURCE: My LG WD-85260NP model Front
LG's 'FE' stands for 'overFlow Error' which I strongly suspect means a service engineer's attention. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Aug 15, 2011
  • 6277 Answers
SOURCE: I want user's manual for Super general Washing
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Posted on Oct 08, 2011
Lost my user manual for my washing machine model Whirlpool 6100
You can down load an electronic copy at http://www.washingmachine-manual.com/whirlpool-awod-6100.html in a .pdf format. Save it to your computer if you do not require a full printed copy. Once saved, you can print select pages whenever needed.
Oct 14, 2014 | Washing Machines
SGW-7100 s
No question there !!
Aug 11, 2014 | Washing Machines
Super general washing machine (SGW 5800) front loader wont stop
Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
Apr 29, 2014 | Washing Machines
Super general SGW7100 E1
my washing machine super general sgw7100 has error E-62! how i solve this problem?
Feb 19, 2013 | General Electric WHDSR209DWW Top Load...
Super genral washing machine sgw 615 belt detail
Could you please describe the problem you are having?
Oct 17, 2012 | Washing Machines
Model # WPSE7300AOWW washes for appox 7-10 min then will go into a super slow movement and even stop sometimes
Dear Sir:
1) Test the timer for defective, clean contats, repair wires loose, burn, or break see how to test.
2) cold water supply problem: see if there are water coming, test the filter for clogged or dirty.
May 11, 2012 | Washing Machines
I want user's manual for Super general Washing machine Model SGW626.could you please help me
Manual
John C.
Oct 08, 2011 | General Electric Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
