Question about Moultrie 30-G Feedcaster Fish Feeder HF30
Not working not throwing out food
GE Sensor Microwave Oven made in 2008 doesn't heat up food
If you do not have any electrical / electronic repair experience I suggest replacing your microwave oven. The cost for repair might be excessive depending upon where you live and you might find a newer microwave oven with features that you like which were not on your older model. The prices of microwave ovens have become lower in recent years and that almost makes microwave ovens "throw away" devices. It has happened to radios, televisions, etc. I used to be in the repair business and the throw away stuff pretty much ended my business.
Feb 10, 2015 | GE Microwave Ovens
We had a freon leak, I wondering do we need to throw all the food away that was in the freezer??
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
Dec 05, 2010 | GE Freezers
Timer works but machine doesn't turn/run
It sounds as if you may need a control board for your food processor, it could be that there is a loose or burned connection inside your unit and could be fixed by disassembling it. another option is to call the Cuisinart phone line located on the bottom of the processor or on the user manual. Unfortunately most control boards are too costly to repair or replace, and your machine is not under warranty. most times they are deemed a ``throw away``. hope this helps.
Thanks
Oct 11, 2009 | Cuisinart SmartPower Premier Duet...
Need replacement bowl for Black & Decker Food Processor CFP10
Contacted customer service and part is discontinued. Purchased a Cuisinart from Amazon.com.
Aug 31, 2009 | Black & Decker FP1400 Quick N Easy Plus...
Frezzer works but the fridge does not keep any food cold, food is beung throw away
If the appliance is nofrost and new keep the air outlets open do not put food infront of them.this can dramatically effect the performance.If it is an old appliance which runs for a while correctly but this happens check the flap is functioning correctly.You can do it by open the fridge door press the door switch button put your hand to the air outlet if it air comes after a while it funcitons if not that means flap is malfunctioned or blocked.empty the appliance leave doors open for 12 hrs. restart if not function no way change it.
Jun 30, 2009 | Refrigerators
Dishwasher throws food
check for filter on botton around pump and clean it
Feb 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Won't come on at all
If you do not have the main dish hooked up correctly it won't come on. I don't know the correct terminology, but there is a lip on the clear cup that slides into the control panel on the left side. It must be a safety major, because if that is not in place it will not work. Hope this helps. Don't throw it away. Deanna
May 21, 2007 | Hamilton Beach 702R Food Processor
Moultrie 30-G Feedcaster Fish Feeder HF30 Logo
106 people viewed this question
Top Moultrie Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Moultrie Fish Expert? Answer questions, earn points and help others
