Question about RST Outdoor Portofino Signature Patio Resort Umbrella
How do I get a manual? I need a manual to assemble the umbrella. I cannot find the one I got
Where I buy the Umbrella with J-Hook Handle in best Price?
Umbrellas are the need of every season whether it is the rainy season, winter season or summer season. But the problem with the umbrella is of carrying it, sometimes we forget also outside. The best option to avoid such kind of problem is to have foldable umbrellas so we can keep it in our bags or carry easily. You can buy the Umbrella which had J handle with many options.
Sep 15, 2016 | Garden
I need a new umbrella for my large Cantilever Umbrella where do I get it and how do i fit it
There are many umbrellas available in the market to cope up with strong winds. There's almost nothing more frustrating than walking through a storm and having your umbrella turned inside-out and destroyed by a strong gust of wind. Many umbrellas experience breakage in this way, leaving their owners exposed to the elements. To have more options you can look on Travel Umbrella.
Aug 10, 2015 | Baby Gear
Hye! can we use umberella lights with this cemers kodak z612 ?
To use umbrella lights, you need a hotshoe connection on top of the camera to attach a radio transmitter. This would set off the umbrella lights. Some high-end DSLR cameras do this very well.
Sep 14, 2010 | Kodak EasyShare Z612 Digital Camera
Harley motorbike why blow back thru new motor 4000 k,old
Regrettfully, all Harley engines suffer from this problem to a greater or lesser degree. It is due to the use of the single crankpin design of the engine. This design is what gives the Harley-Davidson it's distinctive sound but it does create a tremendous amount of crankcase pressure. This is due to the two very large piston moving up and down in unison with each other.
The late model engines went to what we call a "head breather" design in that crankcase pressure is relieved at the top of the engine rather than the earlier design that relieved the pressure at the lower side of the engine. This is accomplished by the use of "umbrella valves" in the center piece of the rocker box covers. The "umbrella valves" are made of synthetic rubber and open and close the breather passages from the rocker box to the air filter box by flexing in responce to the crankcase pressure. Due to repeated heating and cooling, the umbrella valve gets a bit stiff and fails to seal completely allowing oil to be blown into the air filter. Sportsters are more subject to the problem than the Big Twins for some reason.
Most people purchase one of the aftermarket crankcase breather systems and install this or they simply reroute the crankcase breather to the underside of the engine using longer hoses and plug the holes in the backside of the air filter assembly.
However, if the laws in your area preclude you of making any modifications such as this, I would purchase a K&N washable filter and install it in the air filter assembly. These filter are washable and can be cleaned and reused over and over again. As I said, this oil getting into the air filter is aggrevating but also normal unless it gets to where it's pouring out everytime you ride it after cleaning. At point, you need to replace the gaskets and umbrella valve in the rocker boxes. Good Luck
Dec 20, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
Not locking in place properly
I have heard of some defects where the back would not stay up. check with the store.
Dec 19, 2008 | Graco 6D00MEO3 Umbrella Stroller
RST Outdoor Portofino Signature Patio Resort Umbrella Logo
330 people viewed this question
Top RST Outdoor Garden Experts
Dennis Key
Dennis Key
john h
Are you a RST Outdoor Garden Expert? Answer questions, earn points and help others
