Question about Coleman Powermate Portable Generator PM0435003
Pmo 0544655 how do you get roter off engine shaft?
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
Take the through bolt out of the end of the alternator / rotor shaft. it is a long bolt. The shaft from the engine is tapered and unlikely to just pop off. Find a bolt that will screw into the end of the rotor shaft (hardend) find a metal bar that will slide into the rotor long enough so the bolt tightens down on the bar, it will pop the alternator off the tapered shaft
Posted on Nov 18, 2013
Had bed off got all the wireing crossed got to completely wire can you tell me how
Remove No 1 spark plug turn engine till compression felt. align mark on crankshaft pully with mark on timing cover , distributer roter now points to No 1 on cap. Firing order 6 cyl 153624 4 Cyl 1342. check which roter turns and connect cables as above
Jul 20, 2014 | Cars & Trucks
Cant get my distributor installed correctly in 1994 gmc 1500 has a 350 in it?
if you didnot mark rotor orientation before removing pyt engine on top dead center # 1 cyl line roter up to #1 plugwire post on dist cap with a light look down the shaft bore for a slot that matches the end of dist shaft if they do not match p[osition get a long screw driver an turn the shaft in engine until they do then drop dist you may have to turn the rotor backwards about a tooth when you start to drop whn the cam and dist gears mesh it will line up oil pump drive shaft to dist shaft
Mar 30, 2012 | 1994 GMC Sierra
Powermate 5000er 10 hp won't start no fire to the plug
Make sure that the generator is full of oil. It has a low oil level sensor that will ground the spark if the oil is low. If you have filled it to FULL with oil and still have the problem disconnect the low oil level sensor (one wire) and check for spark again. IF you now have spark the oil level sensor has either failed or is dirty. (yes you can clean them with carb cleaner.)
If after doing the above you still have no spark... I need 2 things.
1. the actual model number off of the generator Will start with PM or PMO
2. the engine model number / type / series number off of the engine
Thanks for choosing FixYa,
Kelly
Aug 27, 2011 | Coleman Electrical Supplies
How remove the engine rotor from a 1991 Honda accord EX station wagon. It does not simply pull out as one sources has suggested.
It either pulls right up or on some Honda's where the roter goes over the shaft along the back side (the side that is away from the tabs on the disrtibuter cap) there may be a screw there. I think your does. I hope this helps and good luck.
Jun 30, 2011 | 1991 Honda Accord
Distributer roter not turning
Take off the rotor to see if there is a broken piece. The rotor is made by plastic, but the shaft that it holds on is made of metal and engaged with the gear from the engine. If the shaft is not turning from it is then there is a serious problem; need to visit the auto shop. If it becomes like that because you removed the distributor then try to reinstall it so the shaft gear can engage with engine gears. Good luck.
Nov 20, 2010 | 2000 Mercury Villager
I am asuming this means I have tdc on exhaust stroke now and need to pull dist again and spin roter shaft 180 degrees?
the best way to set the distributer, is to have engine at top dead center. then replace distributer with rotor button pointing to #1 plug wire on cap. have a good day!!
Oct 21, 2010 | 1996 Dodge Dakota
'95 nissan quest stalled at a stop. Will not start, only cranks
I worked on a '93 Quest last year. Couldn't find out why it wouldn't start. It was the distributor shaft not held onto its rotating gear. The roll pin had come out of the gear on the end of the distributor shaft. When the distributor cap was off, the rotor was turning with the shaft while the engine was cranking. So I thought that was okay. But when I put my finger on the rotor and it stopped turning, that is when I found out the problem. It's a stretch, but maybe the techs missed it. Take the cap off, and if you can spin the rotor either way just by hand, the distributor gear has come loose.
Looks like they really covered a lot. I suppose next they will you to replace the ecu. Good luck.
Oct 21, 2009 | 1995 Nissan Quest
Removing the roter from the distributer
there an 8mm bolt going threw the shaft. must be removed then slide rotor of,good luck.
Oct 08, 2009 | 1992 Honda Civic
Coleman Powermate Portable Generator PM0435003 Logo
49 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
