Question about Moen Home
Moen shower control leak
We got a large leak that flooded the floor while the shower was in use. There was no change in the water pressure during the shower. The leak was large enough that the bathroom floor and the adjoining room's floor flooded. We are on well water and have had to replace all of the copper water pipes with PVC due to corrosion. My question is, do we have to cut the old valve out and replace it, or do you think just changing the Moen cartridge will fix it ?
  • 2,708 Answers
Frankly that DOES NOT sound like a valve leak...
... but the alternative of taking the wall apart is pretty daunting.
The cartridge seems futile to me... but I easily done
done at small expense...
While you are at the PLUMBERS SUPPLY...
Pick up some of those SHARK-BITE couplers...
Easy on... easy off SOLDERLESS CONNECTIONS
(see video at bottom).
They make a job like your INCREDIBLY painless...
ALSO REMEMBER THERE are two sides to every wall...
Do pay attention... these work on COPPER, PVC AND PEX...!!
You don't always have to BREAK INTO the wall
from the FROM THE MOST expensive side...
Hope this helps...
youtube video
How to use Sharkbite Plumbing
SharkBite U514LFA 1 2 Inch End Cap Plumbing Fittings for Residential and...
SharkBite U248LFA 90 Degree Lead Free Push to Connect Elbow 1 2 Inch Pipe...
Carnac the Magnificent
Posted on Jun 15, 2017
  • 148 Answers
SOURCE: replace new moen 1200 stem, still leaks due to scratches housing
The proper fix for this is to hone out the scratches
take steel wool and wrap it around a dowel or piece of wood or ust stuff it into the housing and turn back and forth to smoth out the scratch
if the scratch is real dep you wll have to go to harbor freight and get a honing tol that fits on the end of a drill
the stem should have some type of crown washer that you should be able to get an assortment from lowes , ace or hd
If you are asing for a recommendation for a good silicone I always use GE silicone it is the best
as a last resort (if nothing else works to stop leak
I would take cartridge wall and streatch teflon tape as tight and smooth as possible to block water coming up between housing and
cartrideg this is not recomended by mfg just a spa (my initials) certified suggestion
Good luck
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Posted on Feb 26, 2009
  • 102 Answers
SOURCE: low water flow in Shower
Definitely try reversing the cartridge.
Posted on Mar 11, 2009
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
I have a Richmond RCN 0595A12328, MODEL 5V40-7 40 gallon water heater. Can you tell me if there is some kind of an assy. I can use on it so when a toilet if flushed someone in the shower does not get...
The water heater has nothing to do with it. You need a shower control valve that won't let the water pressure change when the toilet is flushed. Moen makes just such a valve called a pressure balancing valve. Moen L82683 Positemp Tub/Shower Valve. http://www.moen.com
Jan 07, 2015 | Water Water Heaters
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
Huge temperature variation in Chateau by Moen shower only faucet
You bet....Pressure at the building varys with large use...8-10am or 4-6 pm....What floor you on...Higher the more pressure you need...maybe a pump...or plugged press.balance system....Not a novice handyman job...
Aug 13, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
91 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
