Question about Pool & Spa
Are the timers on the Hessco tub and spa hooked up as 220 or 110
  • 5,089 Answers
Is this a spring-wound timer?
You rotate the timer knob, and it begins ticking?
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/images/Woods-spring-wound-277.jpg
This type mechanical timer will work with any voltage.
What voltage line do you have?
240Volt has 2 hot wires. Connect 1 hot wire to timer. Timer turns off 1 hot wires, and that action will turn off 240V circuit.
120V has 1 hot wire. Connect this hot wire to timer, and it will turn off 120V circuit.
Be sure you have GFCI breaker or Arc fault breaker on spa circuit.
http://waterheatertimer.org/How-to-wire-Arc-Fault-breaker.html
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Add a comment with more information for best possible answer
Posted on Apr 26, 2013
I need to find an air actuated timer for a spa tub.
replacement units will be available from any good spa and pool shop
Jul 06, 2015 | Cars & Trucks
Waterco 4555100e spa pump
most timers run on a 24 hour cycle may need to reset the timer so the tub will run until the desired tem is reached OR drain some water out and refill with hot water from your in-house heater..help it catch up..
Jan 10, 2014 | Pool & Spa
Hot tub timer turns on the heater but not the pump.
More likely the pump is failing, the pump disconnected or the timer is not connected to the pump. If you run the heater without running the pump then you are likely to do damage to your equipment. I would get it checked by a properly qualified and licensed service technician.
Nov 10, 2013 | Pool & Spa
Can it be put on a timer so it won't come on so often
Yes.
If spa plugs into ordinary outlet, then choose heavy-duty outdoor timer. Use P1261 with GFCI or P1121 without GFCI.
If outlet already has GFCI, do not use two GFCIs
http://waterheatertimer.org/pdf/Intermatic-P1100-series-sell-sheet.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#P1261
If spa is hard-wired, then install T101 for 120volt, or T104 for 240Volt
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T100-series
Oct 28, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Wiring motor hot tub
The wiring diagram should show on side of motor.
Here is basic motor wiring:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Test each lead as shown in following image. In the case of 240Volt, the 2nd wire is not Neutral, but testing is same.
http://waterheatertimer.org/images/Motor-capacitor2-800.jpg
If you have 2 speed motor, then you will have switch or timer controlling the speed:
http://waterheatertimer.org/images/GM40-wiring-2-speed-pump-400.jpg
Oct 05, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
Hot tub trips gfci
spa may be leaking water internally check to see all grounds are hooked up . or you might have a bad gfic
Sep 06, 2012 | Qca Spas Pool & Spa
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
Heeeelp! How to hook up hoses on Sundance spa
There is a skimmer in the side of your tub( the part that skimms water off the top ) and what is called a main drain or a better tearm is deep suction that pulls water from the bottom of the tub and helps collect heavy dirt from in the tub these two lines ( three if there is more than one main drain) These will all come together and then hook to the front of the pump. If your filter is under the skimmer basket the top of the pump will go to the heater and then back to the spa. If your filter in not under the skimmre basket then it will come after the pump then on to the heater. So in answer to your second question, the front of the pump draws the water in and the top pushes the water out. But make sure that your heater is last in line so it only deals with clean water and it will not run on the suction side of the pump as it need water pressure in it to start and contious flow to keep it from over heating. Hope this helps.
Sep 25, 2009 | Pool & Spa
Want to hook it up to my hot tub
Yes, these pool heaters are designed for use with a spa. They are made to accommodate temperatures for both a pool and a spa running off of the same heater. Check the owners manual for specific instructions.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
May 23, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Hot tub wiring
this has nothing to do with computer speakers. it is a hot tub wiring problem...
Jun 22, 2008 | Audio Players & Recorders
Pool & Spa Logo
80 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
