Question about Microwave Ovens
Maytag MMV5165BAS died (?)
My microwave died and shows no sign of life whatsoever. In looking online, it seems it might be a fuse, but when I open it up it is not apparent where the fuse is, if there is one. Please help. Thanks!
    Problem Solver:
  • 13 Answers
Consult a technician for your microwave
Posted on Apr 26, 2013
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave model MMV5165BAS died. No
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven. If it has a hood
thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: We have a brand new
E63 is a "T1 Max Time" error. It indicates a problem on the control board.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Keep a close eye on it, and if it fails again, you want to contact Maytag for free warranty repair.
Posted on May 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: My GE Built-in microwave model JVM1870 appears to have died
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download GE owner's manuals and installation instructions here to make that easier.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 17, 2008
tomsat69
  • 214 Answers
SOURCE: Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
Posted on May 15, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 10, 2009
MMV5165BAS door won't latch
The latch may be broken or defective and will have to be replaced.
Jul 08, 2014 | Maytag MMV4205 Microwave Oven
My microwave shows nothing on display and will not turn on
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
It simply died. It is plugged into the same live outlet as it always has been but now it won't function at all. Not even a time dismay. No signs of life AT ALL lol help!!!
It could be many things, but the first to check in the main fuse (typically ceramic). It will be located near where the power line enters the unit. Check for open with a multi-meter. If open, replace with new (link below). If it blows again, you have other issues that a qualified servicer should address.
http://www.electronix.com/microwave-repair-fuseslamps-c-557_560.html
Aug 21, 2011 | Magic Chef MCD1311ST Microwave Oven
Have a Sunbeam-Oster Bread Maker Model 4810, Style BB-100. I haven't used it in awhile and when I plugged it in there is nothing showing in the display. Pressing the "Start" button also yields...
open the unit and check for an internal glass fuse on the control board,sometimes when they sit for a period of time the fuse wire deteriorates and breaks or by the initial current surge it can burn thru too
Jan 07, 2011 | Sunbeam Microwave Ovens
Maytag mmv 1153aab microwave on start up started then suddely stopped no power whatsoever to unit now normal checks including internal fuse ok
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 25, 2010 | Maytag MMV1153A Microwave Oven
Model mmv5165bas Door handle is broken - how do I replace the handle? Thanks JEFF
If your full model number (from the tag in or on the unit) is MMV5165BAs, then you'll have to replace the entire door.
If your model is one of these, the handle is available separately, with part numbers below:
MMV5165BAB14 or MMV5165BAB15 black part number W10189508
MMV5165BAS14 or MMV5165BAS15 stainless part number W10187840
MMV5165BAW15 or MMV5165BAW16 white part number W10189509
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 06, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag microwave suddenly died after 20 seconds of use - lost all power. Outlet is good. Anyone else experienced this? My cup of tea looks sooo sad - like my wallet... Appreciate your time and...
Replacr the internal fuse you will find when you remove the cabinet. It will be near where the cord enters the cabinet. It is a special fuse ... get a replacement at most hardware of appliance parts stores.
Aug 31, 2010 | Maytag MMV5000 Microwave Oven
Sep 10, 2009 | Microwave Ovens
We have a brand new Maytag mmv5165BAS over range microwave oven. When we tried to make microwave popcorn using the 'Popcorn' control, the microwave stopped early and the display read E-63. What does...
May 24, 2008 | Maytag Microwave Ovens
Microwave Ovens Logo
262 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
