Alto vacuum repair
Carbon brush removal
Unblock my facebook id obaid_dlb778@yahoo.com
Posted on Apr 27, 2013
How to replace a Miele vacuum cleaner motor brush?
You have to disassemble the unit to get to the brushes. It can be quite a pain sometimes, but if the unit is not working and you don't want to pay to have it fixed (most times repair is more then replacement cost), then give it a try. Once you get to them, moist units have a screw cap or metal tabs on the end of the tube the brushes are inside of. Unscrew the cap or bend tabs open to pull the brushes out to replace. On older models you may not get the parts. If you can find any olde type C or D CARBON batteries carefully open them up, remove the center carbon rod and file shape the rod to make you own brushes. Can be messy, but works great when the parts are no longer avaolable.
Jan 01, 2015 | Miele Carina Vacuum Vacuum
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
How to replace central vacuums Carbon Brushes
The entire brush and holder assembly has to be purchased/replaced. That's the plastic piece that screws on to the motor. I don't think you can even get brushes for their machines anymore.
Remove screws. Remove plastic piece from motor. Replace.
Oct 17, 2010 | Electrolux Central Vacuum
Vacuum base is not turning on but brush roller will turn on- Tri Star cannister/hose style
This indicates that you have a bad motor in the machine. If you are able to get power to the rest of the vacuum besides the motor, this means that the vacuum is getting power, and the motor's carbon brushes have probably worn out. I can look and see if the carbon brushes for the motor are availble, or if you'll have to purchase a new motor assembly completely if you can kindly do a clarification request or add a comment to this repair.
Please rate the repair suggestion as helpful by clicking the thumbs up icons if this answered your question.
Thanks,
Chris J.
Mar 21, 2010 | Vacuums
How to install carbon brush
You have to open the case. First remove the transparent plastic on the side then you will see screws on the bottom part of the transparent plastic. Unscrew them and from there you will open the machine. Remove the rexair cover and unscrew the screw that attaches to the 2 carbon brush. When you remove the carbon brush you will see a spring and the copper wire at the end of the brush. remove it and put the new copper wire from the new carbon brush to the contact passing thru the middle of the spring. Then screw it back tightly.
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Eureka capture model 8803 type AVV...runs for 10 minutes then stops. will not re-start for a long time.
This could be a few issues. First it could be the thremel swith located inside, or it could be the carbon brushes also located inside. If you are a do it yourselfer you can purchess the carbon brushes from any vacuum repair shop. The thermal switch should be tested before replacing "thus- you shoud have a local repair shop look at" I would find one that offers free estimates so they can diog. the problem. then buy the part and start the fun part. Saving big $$$$$$
Nov 14, 2009 | Eureka 12 Amp Capture Vacuum Upright...
How to change carbon brushes
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
I need replacement carbon brushes for the motor. I haven't been able to find a source.
Try looking for a power tool repair shop, they usually have some brushes and can order more. I have put Hoover brushes in my Shop-Vac.
Look for some that are close to matching,( spring size,spring length, brush length). If the brushes are a little large they can be made smaller by dragging on a flat file. Carefully fit them so they slide into the brushholder nicely.
I have even soldered different ends onto the pigtails, whatever works----I am a pragmatist!
You could also look for an electric motor repair shop in your area- they have suppliers.
Apr 27, 2009 | Hoover Portapower C2094 Bagged Canister...
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Good armature maybe needs new brushes
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Apr 16, 2008 | Kirby G4 Bagged Upright Vacuum
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
