Home | kawasaki | 19.2V 4 Piece Cordless Tool Kit | Kawasaki 19.2 cor...
kawasaki 19.2V 4 Piece Cordless Tool Kit
Problem for kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 19.2 cordless drill
By Link on Mar 13, 2009
Batteries all powered up, pull the trigger and ...nothing. Trigger was hard to pull, when unstuck, drill wouldn't operate from that point forward. Any quick fix?? I have the same problem of no trigger movement after I picked up my 691220 Kawasaki 21.6V drill from my son's house. I am an industrial engineer and problem solver. I decided because I was attached to this drill that I would disassemble the drill and fix the stuck trigger/switch. After figuring how to disassemble the drill housing I found that the trigger/switch had shorted and melted the switch housing putting the trigger in a bind. The only fix will be to replace the switch assembly. I will call the Service number 1-800-590-3723 and determine if they will send me the switch/trigger assembly 13MAR2009.
Reading the other posts I am surprised there has not been a recall on the drill and not just some of the chargers.
Tim Lechtenberg
lechtet@yahoo.com
Solution #1
posted on Mar 13, 2009
Not Rated)
joboo1
Rank: Guru
Rating: 89%, 183 votes
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Was this helpful?
Yes
No
Popular Solutions for kawasaki 19.2V 4 Piece
Questions and Unsolved Problems for kawasaki 19.2V 4 Piece
Do you recommend kawasaki 19.2V 4 Piece Cordless Tool Kit?
Answer
Answer
Where can you buy new batteries for a JCB cordless drill
Answer
I have two hand tools Black&decker drills / screwdrivers > KC 9018 and KC... (More)
Answer
I have had two cordless drill variable speed triggers burn up and render the tool useless (original... (More)
Answer
how do you connect the wire connections for the power switch?
Answer
screwed 75 2 1/2 inch deck screws worked great, came back the next morning and zip doesn't work.... ... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For kawasaki 19.2V 4 Piece...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
