How to fix lag with the Logitec M150
The mouse keeps lagging, would sometimes stop in place or not move right away. Sometimes it's fine and other times it's a hassle. How do I fix this?
Destinova
  • 46 Answers
SOURCE: Logitec Cordless Lazer Mouse buttons stick
Start by removing the battery cover.. there is a screw on either side of the battery compartment. this will allow you full access to the contacts for the buttons and the wheel Good luck
Posted on Mar 07, 2008
SOURCE: keyboard lags
please make the drivers available in the net to download
Posted on Jun 08, 2008
  • 8 Answers
SOURCE: Logitech Mouse
Where do you have the transmitter sitting? If it is below a desk (i.e., sitting on top of the computer tower, etc.) it may not be emitting a strong or consistent signal. Try moving it within a clear line of sight to the mouse. If that doesn't work, it could be a problem with the mouse itself and need to be replaced.
Hope this helps, let me know
~ Genie-Us IT
Posted on Jun 25, 2008
ve3wtj
  • 147 Answers
SOURCE: MX1000 Laser Mouse
Optical mice often drift, if the surface they are on is less than ideal. Try a mouse pad designed for optical mice. Banging it repositions the whole mouse to a new location optically, where it is able to determine it isn't moving.
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: sticky mouse
Search for out other postings here at FixYa. The sticky situation is one I had, but it was the actual wear inside the mouse buttons to microswitch contacts. I would have to click numerous times to get my mouse to function. The plastic pads get worn after some intense use. Check for our solutions here in other postings.
Posted on Dec 23, 2008
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
I have just brought a Samsung SMART TV and a Samsung BluRay player and we are experiencing audio lag when it plays some BluRay dvd's. The lag is quite severe (3-5 secs) on some dvd's. How can this...
I had the same issue with a Samsung 1580 BD player. Stopping the movie ans starting it again could sometimes solve the problem for a little while. The problem only occured when using bitstream sound. Switching to PCM never showed the problem. The player was faulty and was replaced by the shop.
Jul 18, 2011 | Televison & Video
I have been having an issue where my mouse becomes very slow and jumpy when playing black ops. At all other times it is fine. Any ideas what could be causing this.
Do you experience lag while playing the game? If the game lags, mouse movement will probably lag as well. Do you have another mouse/trackpad/input device you can try? If your other input devices work, it could be a problem with your mouse.
Check to see that you have the latest drivers for your mouse. It could be that obsolete drivers are causing the problem.
May 12, 2011 | Microsoft Wireless Desktop 3000 Keyboard
Automatic transmission doesn't shift into gear right away, there is a long lag before it engages
Hello There
Sounds like your transmission oil needs to be changed, when was it last changed?
Hope this helps, please don't forget to rate me.
May 20, 2009 | 1983 Ford F 250
Genius 8x6 tablet pen freezes
Try putting a new battery in it. Mine was having the same sort of problems, and they were pretty much entirely fixed by a new battery.
Apr 05, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
My logitech cordless mouse keeps throwing the cursor to the top or bottom of the screen while im trying to use it,and its slow to respond when im moving the mouse
Ok, if your mouse is throwing your cruiser around and it is lagging this may mean that you have too much interference between the mouse and the receiver plugged into your computer, first check to make sure that you do not have to many objects between the mouse and the computer and if your mouse uses batteries then you need some new ones in their. If that still doesn't work try unplugging the receiver from the computer and a few seconeds and plug it back in this also works sometimes.
Sep 11, 2008 | Computers & Internet
Lag lag lag lag
Some ways to get rid of your lag is to change internet service providers. If you have a wireless adapter, you may also want to get a new router. If you also have an older router, you may need to change that even you don't use the wireless internet. And for the overheating 360, it should not get hot after that amount of time. Move away from your tv, put it on a flat hard surface.(Not Carpet!), and move it away from a wall that might be preventing it's ventilation.
Hope This Helps,
C13295 ;)
Mar 06, 2008 | Microsoft Xbox 360 Console
Logitech G7 Laser Mouse not responding
Dont worry SourCandy, just use a soft cotton cloth and some mild detergent like a glass cleaner and clean the bottom of the mouse and use a plain dark coloured mouse pad...!!! This shd definitely work..!! Hoping a gud rating from u...!!!
Thankyou
Feb 15, 2008 | Logitech G7 Mouse
Lag Booting
This is a shot in the dark, bare with me. Disconnect everything from the back of pc except the video, mouse & keyboard. Enter your bios. Still have lag? Reset the bios by clearing the cmos jumper pg. 9 in your manual & remove the battery & check it for 3v if you can. If the lag went away by disconnecting the other devices than re-connect one device at a time with a reboot inbetween. When the lag returns you will know which device is not right. Everything applies when doing this kind of search. If you have two dimms remove one. Check for lag. Than swap memory/check. When you boot to the bios it involves the cpu, motherboard, video, memory & power supply. Your hard drive is also an issue but only at booting to OS. Did the pc encounter a unexpected shut down? Did you replace a device like a mouse or a keyboard? Here it the link for your board. ESC shows very little in regards to FAQ's. I hope something above helps you find a answer! http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=674&DetailName=Bios&MenuID=1&LanID=9
Please vote...
Jan 30, 2008 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Computers & Internet Logo
299 people viewed this question
David Payne
David Payne
