Toshiba A305 black screen
Toshiba A305 Satalite Laptop with windows vista stays on black screen after I turn it on. Will not go further or boot up. Any help would be awesome
  • 7,627 Answers
You can start by removing the HDD and testing, replace if necessary. Reseat the Memory Mods as well. Has there been any damage? Drop? I assume the blinking LED is the HDD?
Posted on Apr 26, 2013
SOURCE: Toshiba satellite a105 s4004 cannot boot
if the recovery disk would not run to load the program than your hard drive is probably bad have you been into the machine and seen the hard drive have a look at the front where the wires plug in and there is a slot for jumpers to select the hard drive function make sure its set for master only. most hhard drives will not have a jumper for master setting if there is a jumper make sure its set right .
Posted on Dec 08, 2007
  • 1003 Answers
SOURCE: toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
AvioriX is right your operating system is gone.
if u dont have restore disk get a windows xp program disk from walmart or target or office supply store and load operating system from it.(this will only load windows xp.) but will bring computer back up
Posted on Jan 15, 2008
SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
Posted on Jul 23, 2009
Windows Vista not reading discs
faulty dvd/cd drive by the sounds of things. replace the drive, you can get them off ebay cheep, then give it another go. that will tell u if its a hardware or software fault
Dec 29, 2012 | Toshiba Satellite Pro P300 Notebook
I have a toshiba a305 it turns on says toshiba then just turns black still on all lights and fans but just a black screen
Your system is not producing video output after the POST, which means the Windows video is messed up or there is a problem with a component like memory.
Because you can see the Toshiba splash screen, it tells you the LCD screen is fine. At least you know the LCD screen is working. See if you can get into the CMOS setup screen. I think it may be by pressing F2 on startup. If you can get to that, make sure the hardware is correct (like seeing if your hard drive is seen as installed).
You can also try to press F8 on startup and start the computer in safe mode. Very possibly something is trying to start when Windows starts and not completing its startup.
May 23, 2011 | Toshiba Satellite A305-S6863 Laptop
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
When i turn on my toshiba p200 satalite Laptop, it loads up but then the screen goes black and white before the login desplay comes. i have reimaged it so many time and still the same thing comes...
To find out if it's hardware or software you should boot from a Linux Live -CD  like http://www.pclinuxos.com/ If in there the screen appears normal the the driver from Windows is corrupted - reinstall the latest one you can download directly from the ATI site.
Aug 09, 2010 | Computers & Internet
Toshiba A305 hotkey
Try re installing your operating system (genuine windows xp or vista suggested)
If the problem still persists contact me at
Deepuunni1985@gmail.com
Jul 10, 2009 | Toshiba Satellite A305-S6863 Laptop
To change windows
Just Buy the windows xp.
When u buy it insert the disk and press del. on boot
boot from cd and follow the instructions.
Apr 01, 2009 | Toshiba Satellite A305-S6863 Laptop
Bios information using window Vista
You can install Lavalys Everest program to get all the info about your computer.
Trial version can be downloaded here.
Jan 16, 2009 | Toshiba Satellite A305-S6863 Laptop
I have a new Toshiba Satellite A210 with Vista Home edition installed . I downloaded and installed Windows Vista OS patches to bring machine up to date. Now when I boot the machine, the windows shows the...
hi philipQ
Did your laptop come with restore CDs?, if it did, then i suggest you to a complete system restore. and see if the problem is solved.
i am always here
Thanks
RAhUL
Jun 18, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
