Question about Garden
11a a26m011 wont stay running
11a b29q711 wont stay running
how long does it run for? 5 seconds?? 5 minutes??
May 01, 2014 | Garden
Engine wont start after shutting off to refuel
You most likely have a piece of debris stuck between the needle and the seat inside the carburetor.
May 11, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Where is the fuel filter on a Yardmachine Mod.#11A-41MY229? The mower has only about 36 hrs on it. It seems that its not getting enought fuel. could the carbon cannister have something to do with not...
There is no fuel filter, maybe a screen in the tank. Running good for 20 minutes then shuts down sounds like a coil getting hot then not sparking. Next time it quits check for spark.
Mar 14, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
158cc yard machine, starts then dies.
Your fuel tank and carb need to be removed, both cleaned and replace pump diaphragm between carb and tank. If you want to do it yourself, let me know and I;ll tell you how. Not a difficult job. Dwain
May 26, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Won't stay running
Check the oil level. It may be overfull. If so, a carburetor problem may be allowing fuel to get into the crankcase.
May 18, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Wont stay started
pastorcheri,
I found this site if you can not find plug behind engine/blk wire with black cover boot/ pull off.
http://www.webcrawler.com/webcrawler301/ws/results/Web/Cub%20Cadet%20Online%20Part%20Lists/1/302349/RightNav/Relevance/iq=true/zoom=off/_iceUrlFlag=7?_IceUrl=true
Please rate. Thanks. jj505
Mar 30, 2009 | Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
The high beam relay fails evry 3-4 months
Are you running upsized hiBeams,
the standard bulb is 55/65w,
but is available in 55/90 and 55/130 watt
the relay designed for 11A, wont run with 15A and even less with 22A through the secondary,
also the cable loom goes over some sharp edges, there may be earth leakage from abraded cables, check with ohmneter with lamps unplugged, infinity ohms between cable and earth good, less than infinity problem
not a solution, something to check
Sep 24, 2008 | Toyota Avalon Cars & Trucks
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
