Question about KitchenAid KCO223CU Toaster Oven
Where can I buy the function switch for this oven
    Top Expert:
  • KitchenAid Master
  • 45,644 Answers
From the service agent spares or manufacturer spares
Posted on Nov 29, 2017
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Euro pro to241r
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Oct 10, 2013 | Toaster Ovens
My TRO651 Toaster-R-Oven does not work on any function and the blue light does not come on. I removed the right side cover and checked all the connections, then I cleaned the two sets of contacts with fine...
May not be too hard to fix. On the thermostat, you will see 5 wires coming from it. black and white on top (leave those alone), and on the bottom of the switch, there are red white and blue wires.
The white wire with the burnt connector(from use) is the problem. I had that switch apart, seen how it works. The 3 wires at the bottom (red, white, blue) is like a spst center off switch with white being the common center wire. Red is for oven, and blue is for toaster. After I rebuilt the switch the first time, and it happened again, I just bypassed switch by connecting that burnt bottom white connector, to the red timer wire connector. Oven will work, toaster will not. The oven turns off when timer runs out. Can also unplug or turn down thermostat all the way so it does not use much power when done using till timer runs out. If you have a spst(center off) switch, you can mount that too to the side panel if you find one rated for it. Just make sure the bottom white wire is used as the common center wire.
B&D will not sell that switch that is broken. I tried that before I took that switch apart. Glad I did take it apart as I am sure their new switch would have failed quickly as well.
Aug 02, 2011 | Black & Decker TRO651 Toast-R-Oven Toaster...
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
KitchenAid KCO223CU Toaster Oven Logo
147 people viewed this question
Top KitchenAid Toaster Ovens Experts
Tom Chichester
Bill Boyd
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
