Question about Toro Garden
Traction Cable for Toro 22" recycler FWD (20005)
I am trying to install the traction cable for my Toro lawn mower. However, after I take the plastic shield off of the front, revealing the pulley, I am at a standstill. I have hooked up the black detent (what I call it) to the pulley bracket and the spring on the traction cable is left hanging there because I cannot find a spot to hook it up. I flipped the mower over and I still can't find a spot on the tranny. Is it possible that the part to hook it up broke off sometime? Any help would be greatly appreciated!
  • 24 Answers
SOURCE: cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Posted on Feb 05, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 67 Answers
SOURCE: clutch cable broke
the one on top
Posted on Sep 01, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
  • 1746 Answers
SOURCE: I have a Toro 22 in Recycler Lawn Mower Model No.
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Posted on Jun 25, 2011
20065: HOW DO i REPAIR THE FRONT-WHEEL SELF-PROPELLED UNIT?
Remove plastic cover on front of machine. This will give you a visual on your belt and pulley attached to the transmission. It may be the belt. Check for cracking or glazing on the inside of the belt. You can also try turning the pulley by hand if it is stuck or wobbly then your transmission is junk. Hope this helps you.
Jun 22, 2014 | Toro Power Lawn Mower
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper...
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
Sep 27, 2017 | Toro Power Lawn Mower
I have ordered and received a new traction cable for my Toro Recycler Lawn Mower. However, no instructions. How do I attach this cable so that the mower is once again self propelled?
That can be a tough one the cable that houses the throat cable is the secret to make it work. Look at your old cable and make sure it is in stalled in the same position and work backwards until it works . If the cable is not adjusted right you can not get full power.
Apr 21, 2014 | Garden
My ground speed is very slow can i adjust the travel pedal on my troy built 22 hp 46 in hydro lawn mower
I have the same machine, [pull plug wire for safety] tip machine on it's side, next remove blade, now remove all the plastic shields that are above blade right to the deck bottom. You wont believe the grass build up around blade shaft. On this machine as you select your speed the pulley travels on shaft, but with the grass build up the pulley can't move. I've done mine twice now in the last 4 years. You'll need around 3 hours, good luck it's not that bad.
Oct 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a 2010, 22" Toro Recycler which has broken
I would take it back to where you bought it and demand they fix it under warranty and show you the proper way to stop it. Sounds like it was improperly set-up.
Jul 11, 2011 | Toro Power Lawn Mower
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
Where is the model/serial numbers found on a toro self-propelled lawn mower found?
On the rear of the deck, usually under the black plastic shield. Lift the shield (like you were putting on the bag) you should find a white sticker with black lettering. The model number is 5 digits. If it is a commercial type model, sometimes they hide the sticker behind the handle name plate.
Good luck
Sep 10, 2010 | Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Aug 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
37 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
