Question about Toro Garden
Toro 20005 22" recycler FWD
I'm trying to hook up the traction cable. I have read numerous posts regarding this task, however nobody seems to be having the same problem as me. I cannot find a spot to hook up the spring. The black plastic shield is off to where I can see the pulley... When I flip the mower on it's side I am looking at the tranny and there isn't a spot for me to hook up the spring on the traction cable. Any help would be greatly appreciated!
  • 24 Answers
SOURCE: cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: I hit a rock with my Toro 20331
Hello Again bbaird:
I am Glad I was Able to Assist.
>>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
Best Wishes and Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
Toro lawn mower troubleshooting
A dirty air filter is a common cause of this. Give it a look. Otherwise a replacement carb would be the route to take.
Aug 21, 2014 | Toro 20371 - 22In OHV Recycler High Wheel...
I have ordered and received a new traction cable for my Toro Recycler Lawn Mower. However, no instructions. How do I attach this cable so that the mower is once again self propelled?
That can be a tough one the cable that houses the throat cable is the secret to make it work. Look at your old cable and make sure it is in stalled in the same position and work backwards until it works . If the cable is not adjusted right you can not get full power.
Apr 21, 2014 | Garden
My Dell Studio 1737 operates the F11 from the numerical 1 key!
1 year old banged on the keyboard, and you wish to know if this did it?
Was it okay before that? Not trying to be impertinent, but seems obvious to me.
Suggest you grab that Windows 7 disk, and perform a Repair. (Non-Destructive Installation)
Let's see what this does before we go on.
Post back in a Comment.
Regards,
joecoolvette
May 28, 2012 | Dell Studio 1737 Laptop
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Cable traction needs adjusted
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
52 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
