Question about Frigidaire FMT148GP Microwave Oven
Frigidare microwave has hummimg noise when not in use
My Frigidare microwave ...model # FMV152KWA, has a hummimg noise coming from it when door is shut and not turned on. I put cup of water in it and shut the door. The water heated up. Conclusion is humming noise is microwaves working. I assume something wrong with circuit board. Any suggestions. Thanks Dave
  • 5 Answers
SOURCE: Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Posted on Dec 14, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave is not working
Yes. This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a misaligned door hinge.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 08, 2008
  • 38 Answers
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Posted on Mar 20, 2009
  • 159 Answers
SOURCE: how can u tell which switch is bad on the frigidare microwave
the door switches almost never break it sounds more like no power check the fuses on the pc bords
Posted on May 15, 2009
localwonder
  • 6784 Answers
SOURCE: microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Posted on Jun 10, 2009
I have a frigidare gallery microwave Fgmv175qfa, that has an internal fan that won't stop running and the interior light is on. Tried to unplug for a while, but it comes right back on.
May 24, 2017 - It may be a shorting relay on the the control board, or a problem with one of the door switches or its mount.
I regularly repair these microwave controllers and details are here.
I would need the FCC ID number off the model tag to look up the schematic.
It's best to follow up with me directly.
(FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 10, 2017 | Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Frigidare microwave turns on when the door is opened
<- With a full model number from the tag on or in the oven, I may have been able to give you specific help.
Without that essential information, I can only give more general advice.
I would ask for additional information, but FixYa no longer notifies us experts when such inquiries have been answered.
If you're getting an F7 code in the display, it would have a shorted cook relay, and I repair those circuit board all the time.
If it's not cooking, but just the inside light, turntable and fan are on when you open the door, you may have a bad door switch or other relay on the board.
Jan 07, 2014 | Microwave Ovens
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Went to turn on the mic and heard a pop and now no power. think i blew a fuse. changed it and same thing all over again. any ideas???
I had the same thing to happen to our microwave oven. I went and replaced the fuse in it. Power came back on. Then I tried to pop some popcorn in it. 30 seconds after it started, it made a vibrating noise and shut off. It took the fuse but not the curcuit breaker. The microwave is 14 years old. I have just come to the conclusion that there is buildup all inside the motor parts and that it needs to be replaced. The instruction manuel mentions to replace the monitor switch when replacing the fuse. Since I lost the manuel a long time ago, I asked at Lowes and noone knew what that was....I since found out that it was a safety device installed on the microwave oven so that if the door was not shut completely or was out of alignment, it would throw the fuse. Anyway, I am happy with the service we got with this microwave. It has been through several slammed doors and lots of use. We have been very satisfied with our Frigidare Microwave. It has held up well.
Oct 15, 2009 | Frigidaire FMT118E1B Microwave Oven
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
Microwave door handle came off how do I take door apart frigidare model # plmv 169 dcd
The frame around the door can be gently pryed off and under there you will find the screws you need to remove to replace the handle.
Aug 03, 2009 | Microwave Ovens
How can u tell which switch is bad on the frigidare microwave
May 15, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidare FMV156DCG Overheated?
I have the same problem....I think its the door switch because if you lift up on the door handle while you've got the timer counting down, it should start the microwave hum....
Apr 26, 2009 | Electrolux Microwave Ovens
Frigidaire FMT148GP Microwave Oven Logo
43 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
