Question about Hampton Bay Dryers
My celing fan's lights are blinking like a storve light. Can a part be purchased to fix it?
SOURCE: Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
I have a Hampton Bay # 549HRL and the light won't work it dosen't have a normal starter for the light could it be the remote control but the fan and every thing else works fine please help thank you
Posted on Feb 12, 2008
  • 17 Answers
SOURCE: I have purchased 6 52''celing fsns ,
Call Aloha with a upc number and they will tell you.
The upc number is located on the motor housing on the same sticker as the toll free number. They will be able to help you.
1-800-295-4448
Posted on Dec 23, 2008
  • 37 Answers
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
SOURCE: Ceiling fan light flashes
There is a small part in the light kit of the fan connected to the lighting circuit. The part is relatively common to these fans and is most likely in yours as well. The sticker on the side of it shows model 98480X part number 98480-02. Clip the leads to remove this part and wire-nut the wires back together bypassing it (black/red to black and white to white). This will get your unit back to normal and the switches will still work. I spoke with Hunter and this part has nothing to do with the remote control features of the fan. It is a wattage limiter. If you attempt to put bulbs into the fan that are higher than the recommended wattage this unit steps the voltage down to prevent overheating and possible electrical issues. Removing it will not prevent the fan from functioning but you should be aware that it is in there by federal regulation requirement and without it you could risk electrical failure or fire if you put bulbs in that are too high a wattage. If you call the manufacturer to report the issue they will send you a new lighting housing for your unit which will have a new limiter in it and solve your issue as well. In my case I needed the light working so I bypassed it then requested the part. In the meantime I just made sure that the bulbs I was using were well within spec. In my case the limiter was just on the light, but depending on the model or how the wires were nutted together by your electrician if the fan was also nutted on after this device it would certainly have issues as your bulbs would now be limited to the total wattage of the bulbs and fan combined. Hope this helps all!
Posted on Nov 23, 2010
  • 298 Answers
SOURCE: all of a sudden the light on our hunter celing fan
Three possibility for the strobe problem:
1. Loose wire connection. Shut down the circuit breaker, pull down the switch, open the ceiling fan cover and check for any loose wiring connected to the main bulb, If there isnt any, remove the bulb and spray WD-40 or contact cleaner to the receptacle. Replace the bulb.
2. Replace the bulb with a new one. Preferably incandescent or a warm white energy saver.
3. There maybe ghosts fooling around. (I'm kidding)
Hope this helps,
levibit
Posted on Dec 18, 2010
We purchased a Hampton Bay Southwind V Celing Fan from Home Depot and the glass globe over the light bulb was cracked. Where can we get a replacement? We can't find the information that was in the box.
You can find a replacement at Walmart, Lowes, or Home Depot.
Go to any of the above websites and run a search by entering "light kit replacement glass", or just plain "globe". It should cost between $ 3.50 - $10
good luck
Mar 24, 2011 | Computers & Internet
My craftmade celing fans/lights start strobing
SOunds to me like you have a bad wiring connection in the fan unit, have someone check out all the connections, both between the fan and ceiling and the fan and light unit.
Jan 18, 2010 | Craftmade International Electrical...
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
1-800-295-4448
Dec 15, 2008 | Aloha Housewares (93645) Ceiling Fan
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Dryers Logo
20 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
