I have a honeywell t8400c 1024 (2), as shown in
I have a honeywell t8400c 1024 (2), as shown in the picture attached. When I click the thingy mabob over to air, press the down arrow until I reach my desired degree, the snow flake & a little arrow pointing to "set" begin to blink. I've tried everything! How do I set it? The thing outside doesn't come on, there's no air coming from anywhere, nothing. Help!!
tripletauto
  • 1450 Answers
SOURCE: My A/C outside will not run, inside a fan is blowing air
I am not an a/c expert but mine did this one time and it was the transformer I think it is called pull the panel off and look for wires burnt at connections also. BE sure you cut power off before doing this
Posted on Aug 25, 2008
koolbreezes
  • 540 Answers
SOURCE: digital thermostat not working
Can you saY, Batteries!
Posted on Sep 15, 2008
tborn6
  • 700 Answers
SOURCE: Furnace doesn't reach desired temperature
On the thermostat if its a manual on then pop the cover off and look for a small dial with numbers on it. Take and move it tpoi a higher number than whats it is set at. Its called a heat anticipater and is supppose to make it so that the unit does not oveshoot or under shoot like what your experiencing. If its a digital oine then you are going to have to configure the setting in the insdtallers menu.
Posted on Dec 21, 2008
  • 306 Answers
One of two things you can try. Do you own a volt ohm meter? Anytime your unit cycles short like it is doing the control circuit which on this one is 24 volts that engages relays and controls the gas valve to open and close. I am thinking the heat exchanger is getting so hot it is tripping the upper limit which for the most part is around 180 degrees. So next time it turns off take your ohm meter and with the power to the whole unit off. Either turn the breaker off or there is a light switch that is real close to unit turn it off. Undo the two wires to the gas valve and ohm them out. You should have continuity if you get nothing check each limit switch should have a couple. Undo wires to them and check. If you find one that is open more then likely the upper one. They are a safety device that keeps the unit from getting too hot.
There might be another option increase the speed of your fan motor to get the heat out of furnace quicker. Look at the circuit board notice the fan wiring going to it. The Red wire from fan is low speed look to see if it is on HEAT on the board. You should have 4 speeds to pick from you could take the black off of COOL and swap wires and test the unit by doing that. I'm going to put a solution on this so I can come back to it quicker. Even though we a just testing it for now. ken
  • 10 Answers
SOURCE: DuoTherm rooftop compressor problem
What you are telling us is called shortcyling is caused by possable low refrigerant then the electrical overload is stopping the compressor. overheating can accure.it is best a local serviceman can check it to prevent major part damage.pressure and oil safey controls can cause
simular cylcling problems.
Posted on May 02, 2009
The display on my thermostat T8400C 1024 isn't working. Everything else works but the heat and the flame is not igniting either. Please help.
Sounds like a manual limit needs to be reset (thermal disc). Generally the manual limits are around the exhaust - backdraft, or burner assembly - flame rollout.
Feb 15, 2014 | Honeywell Heating & Cooling
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the PrinterĀ“s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
Aug 19, 2011 | Dell 3010cn Laser Printer
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
Picture sudenly moved down, and pressing AUTO button doesent resolve the problem, I tried it manualy...HELP
Press Menu misvoda, the button on the monitor.
Then press the arrow keys to set the Left-Right size shown by the picture
Press the select key when the option is highlighted.
Do the same with the move option and/or Up-Down size shown by up arrow and down arrow.
Regards
damnor01
Apr 15, 2011 | Samsung 943NW Monitor
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
I have a Honeywell T8400C 1024 thermostat. the last two nights, our heat continues to run without shutting off at the pre-set temperature. We have woken up to 81 degrees in our house. What is the...
Hello
Try taking the batteries out for 5 min,or disconnect power for 5min.
To clear it out.
Then re input all your times days and temps,
Is t stat in a cold location near a door or window?this could also override your settings,most progrmamble stats will go into override at 58.f im guessing this is not your problem.
If it continues after you reset,i would consider a new thermostat.
Hope this helps.
Jan 28, 2010 | Heating & Cooling
Have Lexmark X9350 All in one - Need to block incoming junk faxes
You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
  1. From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
  2. Press select (checkmark).
  3. Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
  4. Press select (checkmark).
  5. Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
  6. Press select (checkmark).
  7. Press up arrow or down arrow repeatedly until you reach the Block List menu item.
  8. Press left arrow or right arrow repeatedly until On appears.
  9. Press left curved arrow to save and exit.
To add each fax number you want to block:
  7. Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
  8. Press select (checkmark).
  9. Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
  10. Press down arrow once.
  11. Use the keypad numbers to enter the fax number in the Fax Number field.
  12. Press left curved arrow to save and exit.
To block faxes sent from an unidentified number (a number with no Caller ID):
  7. Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
  8. Press up left arrow or right arrow repeatedly until On appears.
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Adptive intelligent recovery
On the Pro4000 model you hold the 2 arrows until you go into setup mode. Then arrow up ONLY til you get to option 13. The display will read 13 and 1, press the DOWN arrow and it will read 13 and 0. This turns off Adaptive Intelligent recovery. Now hold the 2 arrows til you see the normal display screen. You are done.
I just did this with a Honeywell tech rep on the phone.
Nov 15, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
