Question about Dewalt 18v Cordless Impact Screw Driver Drill Dc825
Bad Chuck!!! I am trying to replace the bit holder sleeve on my dc825. It will no longer pull forward to release my bits. I have removed the retaining ring, washer and the spring, but the sleeve still will not slide forward. Can anyone help me? Thanks
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
  • 4102 Answers
SOURCE: Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Posted on Mar 05, 2008
Gigatech
  • 259 Answers
SOURCE: dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
SOURCE: stuck bit
I HAD THE SAME PROBLEM AND STILL DO FROM TIME TO TIME. I USE THE PROPPER BITS, SO THAT ISNT THE PROBLEM.
WHAT WORKS IN GETTING THEM OUT... JUST TAP THE BIT INTO THE CHUCK AND THEN PULL THE QUICK RELEASE AND THE BIT COMES RIGHT OUT. THE BIT JUST GETS INTO A BIND AND TAPPING THE END FREES IT UP
Posted on Aug 09, 2008
SOURCE: How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Posted on Jan 29, 2009
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
How to Replace Hilti TE22 chuck
You put the two flat sides on the end of the cap nut and lock them in a vice. You then put a wrench on the back side of the chuck which also has two flat sides. with the cap nut locked in a vise take the wrench and turn the retaining sleeve which has the two flat sides counterclockwise to break the cap nut loose. When it turns freely take the chuck out of the vise and turn the cap nut off. You then push the ribbed locking sleeve down to access an o-ring. You pull that off and it releases the locking sleeve and two roller bearings. You then pull off the retaining slv with the two flat sides and release the other two roller bearings. the chuck will then just pull off the shaft
Hope this helps
Sep 30, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Instructions for a hilti te 22
Without clarification on what is wrong with your tool I can quickly explain how to use it. The chuck has a locking sleeve with ridges on it. You pull it back and insert the bit then release the sleeve to lock in the bit. Behind that is a bigger sleeve. Turning the sleeve and then allowing it to come foward puts it in drill only mode. Pulling that sleeve back and turning it to lock it in puts it in hammer-drill mode. That is about it. A a dab of grease on the end of your bit occasionally to grease your chuck. Hope this helps.
May 09, 2011 | Drills
Cannot get the chuck to release the bit it is a dewalt and yes I am in reverse
On some of the DeWalt drills I have owned with keyless chucks, the chuck has a locking mechanism.
You have to grip the chuck and slide the outer sleeve forward to release the lock, then you can tighten or loosen the chuck.
Apr 14, 2011 | Drills
How do you lock the bits in?
Insert sds bit into chuck with slots/slot matching slot in chuck while pulling back on the spring loaded nose. If the bit does not catch try turning/rotating bit to lock. When you release the nose, a pin will drop into the indention on bit and prevent it from falling out during use. Sometimes this pin will break or wear-out thus the bit will not catch. Before you insert the bit, look into chuck for retaining pin. Pulling back on the spring loaded chuck releases pressure on the pin and allows insertion of bit. Parts are available at www.toolpartsdirect.com
Oct 12, 2010 | Hitachi H45MR 12lb. SDS Max Chipping...
I am having tuff time getting bit tolockin I dont know if have the wrong bit but looks like one in picture
The bit should have one flat spot. There are several types of bits. the most common ones are SDS and Spline.
  1. Align the flat of the bit with the yellow triangle and black hexagon on the side of the tool holder sleeve. Must pull back tool holder sleeve to insert bit fully.
  2. Fully insert the bit shank into the chuck. If tool holder sleeve does not spring into original position, the bit is inserted incorrectly.
I will continue to do some more research on that particular model to find the particular bit type. Please provide a rating if this has been of any help. Good Luck and have a Great Day.
Apr 02, 2010 | Dewalt D25940K Heavy Duty Demolition...
How to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Nov 20, 2009 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
How do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
Mar 16, 2009 | Ryobi 18v Variable Speed Impact Driver...
Stuck bit
I have a thought. How about drilling a small hole from the back(motor side) of the driver assembly and then push out the bit with a small punch? I have considered this, but I don't know yet if the driver is hardened. If this works, the problem should be solved for all users. Then the remaining isue is finding the proper grease for reassembly
Oct 11, 2007 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt 18v Cordless Impact Screw Driver Drill Dc825 Logo
35 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
