Question about Maytag MSD2651 HE Side by Side Refrigerator
Msd2651heb Refrigerator side warm and freezer side frozen over. I replaced the defrost controller but that did not fit it. What else could it be. I am having to defrost it every 4-5 days.
  • Maytag Master
  • 4,654 Answers
If you replaced the 12002495 Defrost Control Board you will have two additional components to check. The 67004757 Defrost Thermostat and the 67004188 Defrost Heater Assembly You will need to manually defrost, unplug power and remove the rear panel in the back of the freezer to get to these two parts. I am adding a video on how to test the defrost heater and defrost thermostat. I will be here should you have questions Thanks Sea Breeze
Posted on Apr 26, 2013
heatman101
  • 43501 Answers
SOURCE: freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Posted on Sep 30, 2010
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 351 Answers
SOURCE: top half warm while bottom half freezing in a side by side fridge
bad evaporator fan and or a defrost problem
Posted on Jun 23, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
hhkgjd
Posted on Sep 29, 2010
Maytag msd2651, icemaker stopsmaking ice & after a few days icesicles are forming and there are frozen puddles throughout the freezer. What is wrong?
Sounds to me your model MSD2651HEB has two problems. If you see icicle forming near where the water enters the ice maker the problem is the water control valve is defective and allowing water to enter the ice maker even after the ice maker is already filled with the next ice harvest. To repair the ice maker overfill problem you will need to replace the=> 67006531 Dual Water Control Valve
10_16_2012_7_51_14_pm.jpg67006531 Dual Water Contriol Valve
. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks, Sea Breeze
Owner's Manuals (1)
MSD2651HEB.pdf (4536.63 KB)
You will need Adobe Acrobat Reader
to view these documents. The Adobe Acrobat
Reader is available as a free
download.
Get Adobe Acrobat Reader
For other models Click HERE
Oct 16, 2012 | Maytag MSD2651 HE Side by Side...
FREEZER FROZEN, REFRIGERATOR WARM
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 13, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer way too cold, refrigerator side too warm on side by side.
This can be caused by lots of faults first inspect the evaporator in the back of the freezer for ice build up if this is the case the defrost system has a fault, if not the unit that opens between the wall of the freezer and the fridge may be faulty check for the grills opening and closing
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer not freezing
The evaporater is located in the freezer section of unit.Defrost thermostat is cliped on the top of it. This is no doubt the culprit. You will need to check continuity on defrost heater and replace themostat.
Jul 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MSD2651 HE Side by Side Refrigerator Logo
82 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
