Question about Acer Computers & Internet
ACER 4750G failed to display properly on Pana 50"
WHen i connect the laptop to P50X30K (50" plasma) through HDMI cable, the 4 edge was trim and only display 90% of the screen. Trying adjust resolution by problem remained. Try to change the HDMI cable also showing the same error. It should be related to TV/Computer problem.. thanks for the help
  • Acer Master
  • 7,627 Answers
Are there Picture settings in the TV menu?
Posted on Apr 26, 2013
Testimonial: "I had try up most of the setting in TV but couldnt locate any helpful setting... :( "
Arius
  • 446 Answers
SOURCE: help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Posted on Aug 09, 2008
Znyp
  • 12 Answers
SOURCE: connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Posted on Mar 14, 2009
  • 38 Answers
SOURCE: IBM Lenovo T60 connection to Samsumg 50'' TV using CGA cable
Try just pressing "Fn" and "F7" keys until the output switches to your TV.
Posted on Mar 24, 2009
joegoldman
  • 335 Answers
SOURCE: no image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Posted on Aug 09, 2009
Amith DSilva
  • 34 Answers
SOURCE: I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Posted on Aug 22, 2009
How can i get a movie from my computer to play on my tv with hdmi
Hook up the HDMI cable to the computer and the TV. Select the proper input on the TV (ex. HDMI 1). Once you have that connected then on your computer hit function 4 to switch your computer display to shared. There will be 4 options to select from but you most likely will want the duplicate display setting.
Apr 20, 2014 | LG 50PQ30 50 in. Plasma HDTV
Connect cable hdmi
Make sure the laptop has diverted its video to the HDMI port. Try this sequence. Lap top off....TV on...connect HDMI cable. Turn on laptop. Switch laptop video to HDMI if it won't do it automatically.
Dec 26, 2013 | Dell W5001C 50 in. Plasma HDTV
I am trying to connect my lg 50'' plasma trying to my lenovo through vga to hdmi cable ,but am not geting display on lcd.
from a cable box you must have the box in hdmi mode turn cable box off with tv on and press menu on cable box remotly scroll down and turn on HDMI
Nov 18, 2009 | LG 50PX5D 50 in. Plasma HDTV
Pink Lines Top to Bottom
The screen has failed. It has about 14 ribbons running along the bottom edge that connect the Boards to the screen, it is glued to the glass and not replaceable. One of the 1000 or so contacts have failed.
It is not good news though at all, screens are shockingly expensive.
Sorry.
Sep 05, 2009 | Toshiba 50HPX95 50 in. Plasma HDTV
No image on hdtv
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Computers & Internet Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
