Question about HP Touchsmart 300-1000 Series,amd Athlon Ii X2 235e 2700mhz,ram 4096mb,640gb
HP TouchSmart 300-1000 graphics
When I turn the computer on for a second it acts like it wants to start but then the fan kicks on high and stays like that until turned off. I figure it may be a graphics chip problem and am thinking of buying a new motherboard. Do you think it'll fix the problem? the drive works fine.
  • 8 Answers
SOURCE: HP ZV6000 Fan Making Noise
I had a similar problem on my zv6000, but I've tracked it down to the fan in the middle (not the one above the CPU with the heatsink).
For anyone else that doesn't feel like taking your laptop apart twice (once to get the part number and twice to put the new fan in after you get it online, etc.), the fan is a Sunon Maglev GC 056015VH-A. HP doesn't carry them in the parts store anymore, but I ordered mine online from an independent retailer.
Posted on Dec 26, 2008
LaptopExpert
  • 458 Answers
SOURCE: My HP Pavilion dv9700 was over heating and would
HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Posted on Dec 05, 2009
  • 37 Answers
SOURCE: the lightning bolt on my hp touchsmart tx2 flashes
that means your laptop has no power so your battery is dead which would explain why it shut down on you, and that means its not charging so it would either be the adapter or the port on your laptop
Posted on Feb 27, 2010
lserni
  • 466 Answers
SOURCE: Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Posted on Feb 28, 2010
Testimonial: "That should do the trick"
  • 381 Answers
SOURCE: i have a hp touchsmart tx2-1012nr that will not
Unplug power.
take out battery
hold power button for 60-90 seconds
insert battery, plug in power cord. power it on.
let me know how you get on
Posted on Mar 19, 2011
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
HP IQ526 white display only
have you tried to connect another display to it? if this is so and the other monitor works than your current display gave out. this is the problem with all in one computers they have poor ventilation and the heat isnt transfered and causes hardware to fail
Sep 06, 2014 | HP TOUCHSMART IQ526 PC PC Desktop
HP Touchsmart 300
If your touchsmart is working then just cuts off then it is overheating, you have two options either buy compressed air and blow out the fans from the grills at the top or take the back off and buy artic silver compound and replace the old compound for the cpu and graphics. Also clean out the fans if you have this open. If you don't know how to open it I would advise taking this item to a computer repair shop
Mar 23, 2012 | Gateway One ZX430001e
Boots up without images on the screen
The graphics card in the PC is very likely faulty. It is possible to remove the graphics card and reconnect the monitor cable to the onboard graphics. Look on youtube for help on removing the graphics card (try a search for iq772). The monitor connector is at the front of the motherboard, near to the graphics card. re-connect it to a similar connector to the left to use the on-board graphics.
Dec 10, 2011 | HP TouchSmart IQ770 PC Desktop
What to do when you turn on computer and see multi vertical colored lines?
This is a known problem with the touchsmart desktops. The cooling on the motherboard and graphics card has a dreadful design and the graphics processors overheat.
The graphics card needs to be replaced, and the HP part number is 5188-7147
Aug 08, 2010 | HP TouchSmart IQ770 PC Desktop
HP IQ770 TouchSmart doesn't load up or stay on
Step 1: Disabling Automatically restart option to view error messages
1. You can prevent the computer from restarting by turning off the Automatically Restart option:
2. Click Start .
3. Right-click Computer , and click Properties
4. Click Advanced system settings .
5. Click the Advanced tab and select Settings in the Startup and Recovery section.
6. Remove the check mark next to Automatically restart under System Failure .
7. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
8. Restart the computer.
Check if it happens again
If it happens again do a hard drive scan(FULL)
Download the latest BIOS update from hp.com
Step 2: Reinstall Microsoft SATA disk driver solution
1. HP Vista computers that use the Microsoft SATA disk driver do not experience automatic restarts. If you updated your Windows XP computer to a Windows Vista capable computer using an HP upgrade solution, this Microsoft SATA disk driver is available to reinstall.
2. To reinstall the Microsoft SATA disk driver, follow the instructions below.
3. Click Start on the taskbar.
4. Click All Programs , PC Help & Support , and then select Recovery Manager to open the Recovery Manager window.
5. If prompted, click Continue .
6. Click Next to continue.
7. The next window asks if you want to perform a program recovery. Select No , and then click Next .
8. The next window asks if you want to perform a driver recovery. Select Yes , and then click Next .
9. Click Next again to continue.
10. Select Standard Dual Channel PCI IDE Controller from the list of drivers, and then click Next . The reinstallation process takes a few seconds.
11.Click Finish to restart your computer.
Feb 02, 2010 | HP TouchSmart IQ770 PC Desktop
My Touch Screen to my HP IQ770 is not working!
There is a well known problem with the graphics card, which suffers from over-heating. You can buy a replacement card (very expensive) or remove the failed card and then attach the monitor feed to the output from the (unused) onboard graphics card. You lose some 3D capabilities, but in normal use you won't know the difference.
This process is described on HP Touchsmart Dev Zone website.
Mar 04, 2009 | HP TouchSmart IQ770 PC Desktop
HP Touchsmart 300-1000 Series,amd Athlon Ii X2 235e 2700mhz,ram 4096mb,640gb Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
