Question about Garden
Mower run for awhile then shuts off. I have changed the following parts,Carb,battery,and selanoid
  • Garden Master
  • 2,478 Answers
Check your gas cap for vent plugged. Or leave cap off and it
Posted on Apr 26, 2013
2 Suggested Answers
  • 7 Answers
SOURCE: My john deere self push mower will not run or keep running unless i pour gas into carb
sounds like the diaphram is bad in the carb
Posted on Apr 06, 2012
Carb float bowl has an electric selanoid on it no wires going to it how does it work and where do wires hook up
Carb solenoid and a fix, dont forget the cut off valve ...
? 10:23
https://www.youtube.com/watch?v=gQw2pQ_oa6o
Jul 16, 2012 - Uploaded by Murray Mayhem
would you advise doing this on a 2004 Bolens with a 15.5 Briggs..... I have a 15 hp Craftsman-koher riding lawn mower that won't run. ... when I put power to it, and the there is gas in the bowlwhen I take it apart. ... Rename the video "How to Bypass Carb solenoid for Temp Fix on no start" Try to edit that ...
Small Engine Repair: How to Check a Solenoid Fuel Shut ...
? 4:40
https://www.youtube.com/watch?v=Kr6UayxyVwU
Jul 23, 2011 - Uploaded by smallengineshop
When the engine is stored with fuel in the carburetor for long periods, there is a .... There is gas in the carb in the lower portion where the float is. .... Engine hadn't been run for over a year and the solenoid would not operate. .... DIY - CarburetorReplacement On Lawn Tractor With Briggs & Stratton Engine ...
Dec 01, 2015 | Briggs & Stratton Garden
I have a yard machine 12.5 b.s..38 inchcut and im getting gas in the oil..if i leave it running it will run alday but when i stop it for awhile it will not start..the oil is full gas n i have to change the...
The carb is flooding, rebuild the carb and be sure to clean the seat and install a new needle.
Sometimes the problem will persist even after rebuilding the carb due to a porous casting. The only way to cure this is to replace the carb.
If I get a unit that has this problem I will install an inline shut-off valve. As long as you remember to shut it off when you are finished usuing the tractor you will be fine; 5 dollars is cheaper than close to 100 for a new carb.
So, rebuild the carb, install a shut off valve and change the oil and you should be good to go.
Also remember to purge the cylinder. Remove the spark plug and turn the motor over by hand to remove excess fuel from the cylinder. Do not use the electric start as the plug wire will spark and may catch the fuel on fire.
Oct 19, 2012 | Garden
Kohler courage 19 starts and runs for awhile then shuts down
see what the voltage is when off and see if it increases running once its running the cltch and the carb solenoid is the only things that should draw it down
May 12, 2012 | Garden
I have a 20 hp honda engine on my cub zero turn mower and i can't get enough rpm to run the mower I take the carb apart to look for dirt and can;t find any but when i put the carb back on it runs fine...
Check and make Shure that it is firing on both cylinders
your can pull plug wires one at a time if the engine speed don't change when you pull the plug that side is not working it also could be your fuel shut off cylinder on the bottom of the carb
Sep 23, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Engine will not crank and the battery is good. Is there a fuse box if so where is it. The mower is a central park cp1642a. Please help What else can I check? How do you check a safety switch if that might...
check your ground wire off the battery sometimes you have to change it or move where it is grounded to the frame. try jumping across selanoid if it cranks then more than likely it is the ground if it doesn't u may need a new selanoid .i have takin my safety switchs and pulled the wire off and jumped across them with a wire if they are just a 2 wire hook up u can check them like that but to me it sounds like a ground wire or selanoid
Apr 18, 2009 | Garden
Crafsman #91725850 riding mower wont start
try jumping across selanoid and see if it cranks if it does not you need a new selanoid if it does u might have to change the ground wire or change where the ground wire hooks up to the frame my not have a good ground
Apr 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1999 7.3L Ford F350 Super Duty won't start
If its got glow plugs chk. with test light make sure there working, also there might be a fuel shut off selanoid that works from the key, when you turn the key it opens to let fuel flow to start, and shuts when you turn key to off, test light that too. And of course chk. all fuses and relays. New fuel filter is a must. Just make sure you fill filter with fuel before you install it. Its been awhile sense its run, its most likely lost prime, maybe a little either will help it pick up, but just a little. you don't want to blow the heads off it.
Feb 07, 2009 | 1999 Ford F350 Regular Cab
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
